billmn
- Joined
- Nov 13, 2003
- Location
- Minneapolis MN USA
- TDI
- 2010 JSW stock:Totaled 2000 black Golf gls 315K : retired
OK I am frustrated!!! I have had an odd stumble on acceleration with CEL (MAF unplausable intermittant) for a couple weeks now and am having trouble figuring it out. I thought at first (using the vag-com and logging it) it was a fuel delivery issue, so I replaced the filter (about 20k miles and 1 year old so it was time any way) but it didn't help. I did the following in the following order, cleaned the snow screen (about 60 to 70% blocked), replaced the air filter (not filthy but getting dirty) , replaced the MAF (had a brand new one on hand), completely dismantled the intake from the front of the car to the MAF, checked the EGR (clean with some oil but no sooty build up), replaced every vacuum line on the car, swapped the ERG and the N75, replaced the N75, cleaned the MAF connector with a good contact cleaner, gooped the MAF connector up with di-electric grease. I am at a loss and don't know what or where to go next. I can reproduce the issue time and time again, it is the easiest to reproduce in 3rd gear if I hold the rpm's at 2800 to 3000 for a couple seconds and then floor it, it will climb for about 400rpm then it will still climb but SLOWLY (feels like 30 to 50% throttle) for about 200rpm, then take off to redline. this happens in every gear but like I said it is most noticeable in 3rd.
I have logged quite a bit with the vag-com and it appears I am truly getting an overboost, but the weird part is that sometimes the fuel IQ will drop to about 65% during the "over boost" and then jump back up to 100% when boost is back to normal. The MAF A vs S shows 1200+ vs 850 requested for 1 to 4 samples, at the same time the MAP A vs S varies by about the % so it truly looks like an overboost, but shouldn't that cause limp mode instead of throwing a CEL for MAF???
Thanks in advance
Bill
Thanks in advance
Bill
