thatguywiththeTDI
Alright heres the deal
06 jetta TDI pkg 2 140k
Thought i had fixed this issue but with the car sitting for a month waiting for the cam change, now that im driving it i realize i was wrong.
Im fighting with a random trunk light/chime. If it was just the light I could deal but the chime is driving me nuts.
It seems to happen when making a right turn or going over bumps
I have checked and tightened all the connections at the fuse block, as well as checked all fuses. I have disassembled the trunk latch and checked all the microswitches they appear to be functional.
If i get out and grab the roof and shake hard it will also come on.
I believe the problem is not located in the trunk, i disconnected all the wiring to the whole trunk right behind the rear seat and took a test drive, the light/chime still came on?
It is limited to only the trunk, when i pop the trunk via fob or key or button on door it opens and shows open on the MFD, once closed it shows closed.
I removed the drivers side kick panel as well as the covers behind the trunk release.
I have grabbed and tugged, shook and pulled the main wiring loom in the footwell but have not been able to make the light/chime come on.
I am at a complete loss here and frustrated to no end...
Can someone please help me with this issue by either diagnosing the issue or explaining where the door chime is and how to disable it via computer or cutting the signal.
i literally spent my last dime on this car with the camshaft and new tires and desperately need help...
thanks so much
thanks so much
