ghitaboamba
I have the following symptoms:
* Rough idle on first start in the morning, even in the summer, for about 20 - 30 seconds (it is longer on colder wheather) then the engine smoothes out and all the starts are ok later during the day.
* If I press my accelerator pedal to the floor while I'm cranking, the symptom is almost unnoticeable.
Compression is good in all 4 cylinders
Battery good
Starter good
Fuel filter new
Air filter new
Glow plugs good
I suspect a fueling related issue ...
Please give me your thoughts only if you had the exact same issue and avoid pouring BS about glow plugs, starter, battery or similar.
Thank you in advance!
Battery good
Starter good
Fuel filter new
Air filter new
Glow plugs good
