vwdsmguy
This problem used to be worse. 30k miles later, this is still anoying. I don't want to take it apart. Do they all do this chatter thing?
Are you talking about the noise with the clutch out in neutral? If so it's the gearbox. One solution is a fluidampr.This problem used to be worse. 30k miles later, this is still anoying. I don't want to take it apart. Do they all do this chatter thing?
Do a couple hard launches. I found my Stage 2 Endurance would get glazed a bit in gentle driving. Driving it hard for a bit smoothed things out.It's a single mass wheel. The chatter occurs as I let the pedal out. I can feel the non-smoothness about halfway out and I think there are not any springs in the disc. This can't be very good for the driveline components, but at least it doesn't slip under power like my VR6 clutch.
True-Do a couple hard launches. I found my Stage 2 Endurance would get glazed a bit in gentle driving. Driving it hard for a bit smoothed things out.
I believe the Stage 3 is more of a "puck" style clutch than the 2. Hence may be more subject to glazing if driven "soft". My own recently installed Stage2 End will shudder if I'm ez on it. I've adapted the driving style a bit by being more aggressive on the revs whenDo a couple hard launches. I found my Stage 2 Endurance would get glazed a bit in gentle driving. Driving it hard for a bit smoothed things out.
I have over 120K miles on my Stage 3 (barely pre-2E, but it was more than 5 years ago) and it's chattered since about 5k on it but has not gotten worse. It's definitely the clutch and not the transmission. It will also chirp occasionally as well as shudder on takeoff, but it's because it's very grabby and does not like to be slipped. The wife hates it but I can feel it clamping down just fine which is a nice sense of security when I want to play. I've gotten used to it and barely notice it anymore.I drove over 100K miles on a Stage 2 Endurance clutch until my DMF failed. Clutch was still in fine shape when I took it out of the car.
