benmarks
I recently had my OEM stereo replaced with an Alpine CarPlay head unit. I got a pro stereo place to do it. As part of the work they did, they replaced my antenna base with one from a first generation Tiguan that has antennas for AM/FM, GPS, satellite radio and GSM (we didn't use the GSM.) The part numbers we used were 5N0 035 501 B for the base and 5N0 035 849 A for the appropriate mast. However, we have noticed that the reception is now very poor. FM stations that I could hear fine last week now have some static and we can't even find an AM station yet. Before I gave the stereo installer all the parts, I hand-screwed on the mast. I didn't use a wrench to tighten it but I thought I had gotten it on all the way. However, I just removed the mast a few minutes ago and noticed some white plastic in the connector that is partially concealing the metal contact in the mast. So, my question is can/should I remove that plastic? And, should I tighten the mast using a wrench? Or, should I be looking elsewhere?
