Nathaniel.Troy
Got my VCDS today finally and I need to fine tune my IQ but I'm not sure what to set it at. I have stock injectors, 11mm pump, inline lift pump, 17/22, stock injectors and no tune. After I did the 11mm swap I did the hammer mod without vcds so my IQ is around 6.0 right now. What number would be best for what I have at the moment? Also is there any other beneficial tweaks you can can do with vcds that I don't know about? I did the doors unlock when you take your key out of the ignition and a few small things like that.
Also I know that it needs to be in between 3-5 normally but I mean would it be better to have it around 3 or around 5 if it even makes a difference?
