Abacus
That helpful B4 guy
Agreed. Frank will be able to tell you how to proceed.
better mileage if you keep your foot out of it, more power when you find yourself with your foot to the floor trying to get out of the way of that dump truck.Excellent. Thanks for the quick response. Will that net better mileage or about the same with a little more power?
I hear ya. I did quite a few things wrong with this poor car. Now with all the money I'm spending you better believe I'm going to try to do things right from here on out.Change the oil and filter as soon as it's bolted in... Not trying to be a smart alec, but with your original post...
Just start off with nice fresh oil in this one. 'Work good, last long time'
i saw that too ninedee, i'm pretty sure all that's getting replaced anyway... it looks like a previous hack before OP purchased the engineIf you don't correct the timing belt tensioner and put the tab/keeper where it belongs, you'll be activating plan I sooner then later.
change the rear sealDon't touch the rear main seal if it's not leaking. When you swap the timing parts over, make sure any one-time-use bolts get replaced. If you're looking to recoup some of the cost, keep in mind that the injection pump from your auto engine is probably worth a little more than the one from the manual engine. The power increase is nice, but any additional stress on the auto transmission is undesirable in my opinion. It's all about risks/benefits, so it's all up to you.
Good eye. I didn't notice until I removed it and it had me worried. It wasn't the only thing that had me worried either but so far everything is looking okay.If you don't correct the timing belt tensioner and put the tab/keeper where it belongs, you'll be activating plan I sooner then later.
Dang, I bet your right. I already put the new belt on but the engine isn't in the car yet so it wouldn't be hard to change out. Probably be worth it.I read that you were considering re-using your timing components. Do not, under any circumstances, re-use a timing belt from an engine that has locked up no matter how new it is. The sudden shock breaks the cords in the belt and it will fail pretty quickly. I know this from experience.
I did actually. Reason being, when I went to remove the harmonic balancer, with the cam plate already installed, the notch on the pulley didn't line up with the mark on the cover. Everything looked fine and I manually rotated the engine with the belt installed and didn't feel any resistance besides compression. I have a feeling it's off a tooth though and will know once I bolt up the trans.if it was me I'd consider pulling the cam and taking a close look at the lifters for damage too.
You, sir, are a breath of fresh air. Thanks for the kind words!Well done! And I like that you kept up with a good attitude during your .....ahhhhh learning experience.....yeah that's it ....congrats on being back on the road!
