Old June 4th, 2020, 03:06   #1
Pike25lb
TDI(s): 2.0
Default Camshaft replacement pd scout
*Camshaft replacement pd
Hi all I'm not sure if this is in the right section*
I have a 2010 skoda scout 2.0tdi pd the cam shaft is worn so I am thinking of replacing it but I dont want to move the timeing side of things also dont have a vcd to fine tune the timeing so is there a way I can just do a straight cam swap and keep the timeing side fixed any vids or advice sure my engine is the same as the jetta 1.9 pd ta
Pike25lb is offline   Reply With Quote
Old June 4th, 2020, 04:26   #2
Mozambiquer
Mozambiquer's Avatar
It's very difficult to do a cam replacement without messing up the timing. My dad tried it on an mkV Jetta for the very same reason. It ended up being one notch off and we had to tow it to a shop which had the tool to get it set. (The guy didn't use the tool though and cut corners so the timing was still off, but it would run) later I got a set of timing tools and set it correctly.
How long has it been since your timing belt was replaced?
Sent from my S60 using Tapatalk
Mozambiquer is offline   Reply With Quote
Old June 4th, 2020, 04:49   #3
Pike25lb
TDI(s): 2.0
Hi not sure when it was replaced or even if it has been replaced
That is my concern if I move the timeing my neighbor's does have a copy of a vcd disk he said I could borrow but I provs wouldn't know what I was looking for with that
Old June 4th, 2020, 05:43   #4
Mozambiquer
How many kms on the car? I'd highly recommend replacing the timing belt, tensioners and water pump at the same time. Otherwise you'll probably have to put an engine in if the belt breaks.
Old June 4th, 2020, 06:38   #5
tactdi
tactdi's Avatar
TDI(s): 2005.5 Jetta
VCDS is not on a disk, it is downloaded from the Ross-Tech website, if it is on a disk, the software and cable is probably a pirated copy, and the disk could be virus infected. Be careful if you do use that copy.
tactdi is offline   Reply With Quote
Camshaft replacement pd Pike25lb VW MKIV-A4 TDIs (VE and PD) 5 June 4th, 2020 03:01
Best replacement PD Camshaft? truck240 VW MKIV-A4 TDIs (VE and PD) 15 August 22nd, 2016 09:51
Best replacement PD Camshaft? truck240 VW MKIV-A4 TDIs (VE and PD) 0 October 11th, 2015 00:05
2004 Jetta PD camshaft replacement wvodiesel VW MKIV-A4 TDIs (VE and PD) 39 January 26th, 2011 21:32
Most miles on replacement PD camshaft hid3 VW MKV-A5 Golf/Jettas 10 May 9th, 2010 01:17
Page generated in 0.12902 seconds with 11 queries
[Output: 69.48 Kb. compressed to 61.53 Kb. by saving 7.95 Kb. (11.44%)]
