Old May 8th, 2020, 00:17   #1
Texas_sky
Fuel Economy: unknown at the time, waiting for engine swap
Default 06 Jetta TDI died on freeway, won't start back up.
2006 Volkswagen Jetta TDI BRM 1.9 Diesel Automatic DSG 144,000 miles
Was driving today felt a little vibration and engine died. The car has a known bad flywheel that I was planning on fixing before 150k. I felt a vibration and then the rpm just dropped to zero no loud noises or anything, oil level still good. Turns over but won't start, the sound I'm getting almost sounds like similar to a compression test. Hopefully engine is still good, if flywheel did take out the engine what type of sound would have happened and what should I look for? Camshaft was replaced less then 10,000 miles ago at the dealer, all maintenance current.
No CE lights on or anything right now. Will take a deeper look at it tomorrow and also get another opinion from a VW tech soon. Located here in Aurora CO near Denver off I-70 if anyone is up for taking a look at it. Was driving to Boulder on HWY 36 today doing a lyft ride when this happened cruise control on at 80 mph. Any help and advice appreciated.
Texas_sky is offline   Reply With Quote
Old May 8th, 2020, 04:24   #2
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Pull the timing cover and take a look at the timing belt.
oilhammer
www.cardocautomotive.com
Old May 8th, 2020, 06:40   #3
Mozambiquer
Mozambiquer's Avatar
If it sounds like a compression test, sounds like a timing belt...
Sent from my S60 using Tapatalk
Mozambiquer is online now   Reply With Quote
Old May 8th, 2020, 09:03   #4
Texas_sky
If the timing belt broke the engine is toast right or at least the cylinder head? I'll go out and check here soon. A VW dealer changed the timing belt/camshaft less then 10k ago up in MT where I bought the car, should still be under warranty given I have the documents, could the bad dsg flywheel have anything to do with it?
Old May 8th, 2020, 10:32   #5
oilhammer
oilhammer's Avatar
This thread exists in no small part due to dealers being unable to properly install a TDI timing belt:
http://forums.tdiclub.com/showthread.php?t=212873
One of my Golfs I own now I got on the cheap because a dealer timing belt job quickly resulted in several smashed valves, two bent rods, and three shattered pistons. Their response to the previous owner: "It's old, they break".
So don't expect much. Sorry.
I kept track one year, and came across a total of 17 botched dealer timing belt jobs... not all of which came into our shop under their own power. Most didn't.
oilhammer
Old May 8th, 2020, 10:39   #6
Texas_sky
Oilhammer, thank you for your input and advise. It is unfortunate that they can't preform quality work on these cars.
I just went out and took the timing belt cover off and it appears not to be broken. I wasn't able to inspect the lower half. If belt is broken it would be loose correct and I could pull it off? I'm still wondering if the FW shattered and took something out, how would I find that out? Also forgot to mention the car has been sitting sometimes for up to 3 months at a time when I was leaving town. I never let it sit longer then 3 months without at least a mile or two drive.
Old May 8th, 2020, 15:04   #7
kdawg89
My buddy had a similar issue but the tensioner failed and it chewed the teeth off the belt by the crank. You need to have someone crank the engine while the timing cover is off and see if the cam rotates.
15 Golf TDI SEL DSG, Kerma TDI Tunes, Malone DSG Tune
Sold:06 Jetta, Darkside GTB1749V turbo, stage 4 malone tuning, 3 bar map, EGR delete, ASV deleted, buzzken catless downpipe, IDParts billet cam
kdawg89 is offline   Reply With Quote
Old May 10th, 2020, 13:20   #8
Texas_sky
Sounds similar to post #14 here, I checked my timing belt and it feels tight.
https://forums.tdiclub.com/showthread.php?t=307553
See post #9, can someone tell me what the problem is in this picture?
https://forums.tdiclub.com/showthread.php?t=432910
Old May 10th, 2020, 13:32   #9
kdawg89
The belt in that picture has no teeth. You should be able to watch the cam while someone else tries to start it and see if the cam is spinning with the rest of the engine.
Old May 10th, 2020, 13:57   #10
Mozambiquer
My belt is looking similar to this. See post #9, can someone tell me what the problem is in this picture?
Sorry to tell you, but your head is probably toast.
Old May 10th, 2020, 14:22   #11
Texas_sky
I just checked the belt and it's still in good shape, all the teeth are still on the belt. Possibly I got a bad tank of fuel from shell, it was a station with non shell fuel (this is not a shell product) at the pump.
Old May 11th, 2020, 03:45   #12
Tdijarhead
If all the teeth are present, set the engine to TDC to make sure it’s still in time. Then maybe you can consider the possibility of bad fuel.
When a belt breaks it disappears, wrapping around the crankshaft. It looks like this. My daughter bought this Jetta cheap because someone tried to go beyond 150k on a belt change.
Tdijarhead is online now   Reply With Quote
Old May 11th, 2020, 05:22   #13
Mozambiquer
Ok, so your statement above about your belt looking like the photo in that one post was missing the fact that the belt in that photo had a bunch of teeth missing. If you're not missing teeth, maybe it's not toast, unless it skipped time. You mentioned that it sounds like a compression test when you crank. Is there any way you could get a video of that?
Old May 12th, 2020, 13:19   #14
Texas_sky
I'll try and make a video, how would I post it here on TDICLUB?
Old May 12th, 2020, 13:59   #15
Mozambiquer
Upload to Google photos or YouTube and post a link.
02 Jetta TDI died while driving. Won’t start back. Help?! Wgarner1414 VW MKIV-A4 TDIs (VE and PD) 7 February 9th, 2019 10:29
02 jetta TDI died and won't start now. dood51 TDI 101 5 February 14th, 2011 12:47
06 died won't start Rockcrawler VW MKV-A5 Golf/Jettas 4 June 28th, 2010 06:04
Car died on me and won't start back up rivers24 TDI 101 40 November 16th, 2006 23:32
tdi jetta 06 won;t start caper7 VW MKV-A5 Golf/Jettas 2 March 10th, 2006 06:18
© 1996 - 2020, All Rights Reserved
Page generated in 0.18640 seconds with 11 queries
[Output: 135.05 Kb. compressed to 113.20 Kb. by saving 21.85 Kb. (16.18%)]
