jimmer2880
You can probably label me a lurker, since I very rarely post. That’s because I really don’t have anything of value to add that everyone else already covers.
I’m know this topic has been covered many times before, but for all the searching I do on this site, I’m still confused about what to do next.
Car info:
01 Jetta TDI
170,000 miles
Purchased at 155,000 miles in Jan of this year
Bone stock
Because I only bought this car in January, I don’t know how long ago the AC might have actually worked properly. A couple weeks ago, on a 90 deg day, I noticed that the AC wasn’t doing much (if any) good. So, I purchased a DIY, add a can kit to add some 134. IIRC, the system had ~25 PSI. I bumped it up to ~35, and it “appeared” to do some good. However, the next day, I was back to worse than I was before. I’ve been reading ever since. In the mean time, I purchased a set of gauges. It appears that the compressor is working. The clutch appears to engage (hard to see from above), and when I press the “AC” button, the rpm’s very quickly drop. My best guess as of today, was that I had over-filled the system. So, I got out all my gauges and started to hopelessly work on it tonight. The Temps were taken with a Craftsman digital multi-meter with a temp probe (not the IR kind).
After driving the car home from work (1.25 hour drive) with the AC on high the entire way. Here are my numbers, please let me know what you think:
Ambient outside air temp 86 deg
Low pressure reading: 30
High pressure reading: 100
Vent air temp: 86 deg
High pressure reading: 90
Vent air temp: 94 deg (notice, it’s higher than the outside air temp)
High pressure reading: 80
Vent air temp: 95 deg (notice, it’s higher than the outside air temp)
High pressure reading: 60
FWIW - I was bleading the Low-pressure side. The Low pressure would drop, then raise, then level back out at 30. Now I’m stumped. What should I be looking at next? I was thinking the dryer/filter and/or the expansion valve.
Any help would be greatly appreciated.
Car info:
01 Jetta TDI
170,000 miles
Bone stock
