Old September 17th, 2018, 02:05   #1201
jason_
Besides free and it makes heat, no reason at all honestly.
Sent from my 2PS64 using Tapatalk
jason_ is offline   Reply With Quote
Old September 17th, 2018, 05:27   #1202
740GLE
Almost 6 quarts of oil does take a long time to heat up, even our TSI hardly gets the oil up to temp (190F) on my 7 mile drive to work in the summer.
Old September 17th, 2018, 07:34   #1203
jason_
My concern is that insulation and plastic cover over the aluminum pan itself.
I'll trim some padding out and snake the leads through, but will the heat upset the plastic or foam?
Maybe I'll bench test it if I get time and see what I end up with. It can always be added later easily.
Old September 17th, 2018, 07:36   #1204
chrislane31
TDI(s): mk7 Golf TDI
Full clutch/brake fluid flush and Euro short shifter install. Wanted to get rid of that stock fluid that just sat around in the car for over a year.
Buy my B4 Passat TDI/VR6 parts
JTL
chrislane31 is offline   Reply With Quote
Old September 17th, 2018, 13:48   #1205
sportwagen3
Any tips on removing the shift lever? I tried to get it off one time and it seemed stuck and would barely budge.
sportwagen3 is offline   Reply With Quote
Old September 17th, 2018, 14:16   #1206
chrislane31
My buddy was doing the brake.clutch fluid flush and had to remove the intake for the slave, so I just had him do it, sorry.
JTL
Old September 17th, 2018, 17:56   #1207
Discovery
A roof basket
Discovery is offline   Reply With Quote
Old September 17th, 2018, 18:15   #1208
adjat84th
adjat84th's Avatar
Lightly tap with a hammer while pulling up. It will give eventually!
Sent from my Pixel 2 using Tapatalk
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTD1752vrk, 4bar MAP, CP3, Peloquin LSD, DC stage 3 w/ SMF, Fluidampr
Old September 18th, 2018, 05:02   #1209
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Fuel Economy: Great!
Nice! I will be interested in what kind of fuel mileage hit you're going to take and I wish that we weren't required to have front license plates here in MD...
Originally Posted by Discovery View Post
A roof basket
-George Bernard Shaw
Old September 18th, 2018, 07:38   #1210
740GLE
hopefully the oil heater is thermostatically controlled so it doesn't heat the oil any more than NOT of 190-250F.
To make you feel better some "GTI/R bois" track their cars and routinely see 260F oil temps with their plastic TSI engine pans, you may be over cautious.
Old September 18th, 2018, 22:10   #1211
Discovery
Well I don't drive to save fuel, but so far on highway I noticed a increase of 1L/100km. Basket empty. I removed it to seal the joint with caulk.
Old Yesterday, 10:56   #1212
fase2000TDI
Fuel Economy: 52, 45 38
"DELETED"
That's subtle
TDI service available - timing belts, clutch jobs, cv joint rebuilds, engine rebuilds, maintenance, low power diagnosis, suspension. DSG service $180 Have CAN VCDS for CR TDI's PM here, call or email JeremyTDI@yahoo.com (401)-919-0466 Quotes available, very fair rates
fase2000TDI is offline   Reply With Quote
Old Today, 09:45   #1213
Discovery
Yup.
I received a few PM about the basket so here it is:
https://www.amazon.com/dp/B004R34HDC..._P48OBbYE8WYFN
Without 18" extension.
Cross bar are from a 2002 a4 wagon.
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
New mk7 features not highlighted. 03_01_TDI VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 45 October 16th, 2015 18:37
Took a Mk7 GTI for a drive today... Nuje VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 1 July 23rd, 2014 13:51
Golf Mk7 Tfinn VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 11 August 29th, 2013 09:02
MK7 2014 Golf elitegunslinger VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 29 September 10th, 2012 10:55
Page generated in 0.16132 seconds with 10 queries
[Output: 116.64 Kb. compressed to 98.20 Kb. by saving 18.45 Kb. (15.81%)]
