Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Mid-west USA
Mid-west USA Local discussions for those on the Mid-West US. ( Minnesota, Iowa, Wisconsin, Michigan, Illinois, Indiana, Ohio, Nebraska, North Dakota, South Dakota, Kansas, Missouri)
Old March 26th, 2017, 19:17   #7666
[486]
TDI(s): 02 golf ALH
on the ones I did I just unbolt the motors from the calipers,
then use a straight blade screwdriver in the torx hole to retract the internal parking brake mechanism
then squeeze the outer piston in with a pliers or whatever
then bolt the motor back on
there's only two wires going to the parking brake motors, it just applies 12v in one polarity for a set time to apply them, then applies 12v in the opposite polarity for a set time to release. No position sensing to worry about (maybe current sensing to shut off when the motors stall out at the end of their travel)
[486] is online now   Reply With Quote
Old March 28th, 2017, 09:09   #7667
Namakan
Namakan's Avatar
Default Looking for new rockers
I'm trying to source a new set of rockers for a 2002 Golf locally. Anyone have a recommendation on who might have some in stock?
2002 Golf GLS TDI 5sp (mine) - Malone Stage 1, Ventectomy, Cupholder Mod, Frostheater, 2011 JSW DSG (wifes car - now gone), 2004 Jetta (gone)
Namakan is offline   Reply With Quote
Old April 1st, 2017, 15:16   #7668
joey944
joey944's Avatar
Does anyone local ish have any stock exhaust (mkiv alh) that you're looking to get rid of super cheap or free?? My flex pipe is blown out and my muffler delete rotted and came off. Please send a PM if you know of any. Thank you!!
Joey Kasper,
Owner/Operator:Joey's Mobile Detailing Inc.
612-327-8586 http://www.joeysmobiledetailing.webs.com
joey944 is offline   Reply With Quote
Old April 1st, 2017, 23:22   #7669
[486]
TDI(s): 02 golf ALH
Eh, mine's pretty hacked up
The pipe itself doesn't usually rot out as it's some sort of ferritic stainless, I feel as though it's a little higher grade than the 409 that american cars get. The hangers however do fall off regularly, and the resonators come apart (did the diesels get those or were they gas only?). Mine had a piece of EMT welded in after the cat, back to the band clamp.
Find an exhaust shop that'll weld in a new flex pipe and hangers.
Old April 3rd, 2017, 20:45   #7670
Curious Chris
Fuel Economy: 47/42/38
Ok here is an easy one: i accelerate hard, then when I brake there is a clunk I can feel in the brake pedal so it is coming through the subframe. Does it a lot one day and then just seems to be random. I jacked up the driver's side and there was no obvious clunk but a little movement in the 3:00 o'oclock/9:00 o'clock. LCA? Tie rod? I am betting LCA.
Curious Chris is offline   Reply With Quote
Old April 4th, 2017, 09:46   #7671
SpamJ
SpamJ's Avatar
Fuel Economy: 52/45/30
I vote LCA (bushing), but have you looked at your motor mounts?
Sam
02 TDI Jetta Wagon
Not Insane
SpamJ is offline   Reply With Quote
Old April 4th, 2017, 10:55   #7672
Stan TDI
Dog bone is another possible choice Chris. If you jack it up and use a prybar, you can typically see what is moving. I had a similar issue and it was the dogbone.
2002 Jetta GLS - auto to manual, VR6 clutch, sprint 205s, panzer full metal jacket, DG short shifter
2002 Jetta GLS - stock for now
Stan TDI is offline   Reply With Quote
Old April 4th, 2017, 10:57   #7673
Stan TDI
Originally Posted by Kriesel View Post
I used some headliner glue to spray it back up. It is no longer sagging... I didn't try to re-stretch it in a couple spots, so I can still see the headliner backing material in a couple places, but only if I'm trying to look for it. Otherwise, all-in-all, it's not sagging.
Here's the stuff I bought from amazon:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Thanks Kriesel! I will order some and try it out. It is not sagging too bad so far thank goodness.
Old April 5th, 2017, 18:20   #7674
Curious Chris
I have replaced all my motor mounts in the last 3 years. I am betting LCA though I check the driver's side and nothing so when I have time I will check the passenger side.
Old April 7th, 2017, 20:59   #7675
astrolumen
astrolumen's Avatar
Default FS: 2002 VW Golf TDI - Diesel 5-speed - 217,XXX - $2600
SOLD!
Hi MN TDI Peeps,
I'm selling my 2002 Golf TDI. See posting here:
http://forums.tdiclub.com/showthread.php?t=476064
http://minneapolis.craigslist.org/ra...079053752.html
Bjorn
'02 Golf GLS TDI 5m: Panzer Skidplate, Scangauge, Frostheater
astrolumen is offline   Reply With Quote
Old April 7th, 2017, 21:25   #7676
TornadoRed
TornadoRed's Avatar
If I did not already have two Mk4 Golf TDIs, I'd jump on this in a heartbeat. You'd have my deposit tonight.
'03 Golf with 741k miles: Bosio DLC 764, GT1749VB, PP 2.5" downpipe, Malone tuning, VR6/G60 clutch/flywheel, Bilstein HDs, Recaros, Akebono pads/Brembo rotors, Cat filter with Nicktane head, DG Panzer w/FMJ, Blizzaks, TDT or Delvac1
Like TDI Club? Got PayPal? Got $1 or $5 or $10? Contribution link on the main page.
Old April 10th, 2017, 09:36   #7677
najel
Originally Posted by astrolumen View Post
SOLD!
Hi MN TDI Peeps,
I bought the car from Bjorn, nicest guy you'll ever meet. Thanks for the easy transaction!
I'm excited to get insurance on it now and start driving.
najel is offline   Reply With Quote
Old April 10th, 2017, 14:39   #7678
rbrennick
Default Anyone Know This Car? Minneapolis/ St. Paul area
Hello from Michigan-
Checking here to see if anyone on the forum knows this car:
Just bought from Hudson Ford Used Cars/ Hudson, WI (St. Paul, MN area):
Guessing it was a trade in?
2003 Jetta Wagon TDI- Baltic Green/ Tan Leather 260k
Was originally an auto trans converted to 5 speed.
Records up through 200k, and I know someone after that put lots more time
and money in it, as it has lots of newer stuff: Darkside race pipe/ EGR gut,
newer Bilsteins, tires, brakes, etc. Pretty nice car.
Anyone know the car or the person that recently owned it?
Just want to fill in the maintenance blanks...
Thanks- a PM would be fine.
Rich Brennick/ Michigan
rbrennick is offline   Reply With Quote
Old April 10th, 2017, 16:34   #7679
TornadoRed
TornadoRed's Avatar
You need to talk to Eric Merker, who knows about this car I think and told me about it. From what I heard, the lady traded it in without telling her husband, and he was not happy.
Old April 10th, 2017, 16:58   #7680
rbrennick
Ha, OK, thank you for the lead. Sent Eric a PM.
Best, Rich
Page generated in 0.23352 seconds with 10 queries
[Output: 130.19 Kb. compressed to 108.69 Kb. by saving 21.49 Kb. (16.51%)]
