G
gboss
Guest
Ok, I've read all the posts about other people's problems with b4 limp mode under acceleration at highway speeds. I have had this same problem for a little while now and have been trying to remedy this.
What I have done so far is:
Replace N75
Replace all vacuum hoses (except i think the last segment of the blue one that goes to the turbo, i couldn't get down to take it off on the turbo end). I also wasn't able to replace the one that goes into the firewall near the heater hoses (anyone know what that one is?)
I removed and cleaned the vacuum source hose that goes to the brake booster and verified the check valves are clear.
I just installed a boost gauge to see what was happening with my boost. The car is stock.
It has an aftermarket (generic midas, etc [yuck]) exhaust and it just had the intake manifold replaced under the recall.
With the gauge installed (t'd off the line that goes to the ecu) I have been seeing sustained 20psi under WOT (SIC) and when I hold it at 20psi in 3rd for a few seconds, that's when the limp mode kicks in. After limp mode, i see 5-8psi under full load. Recycling of the ignition restores full boost. I am thinking that I am somehow seeing too much boost as 20 psi is more in the range of chipped tdis. It doesn't feel like i'm getting 20psi of power (probably fueling). I also just replaced the fuel filter.
Does anyone have any ideas as to what my next move should be?
I had initially thought that the exhaust was too restrictive and the turbo didn't have enough pressure differential to make enough boost but now it seems that i'm getting too much boost. Could those last 2 vacuum lines be the problem?
I would appreciate ANY advice that anyone could give me as I am pulling my hair out over this at this point.
thanks
greg
Replace N75
thanks
greg
