Old March 17th, 2009, 15:15   #1
whiterabbit7
Fuel Economy: 35/56/43
Default running cold and poor starting
I think I am having two separate problems. The car has started always running cold. About one notch below 190F. Should I be worried about this? What do I do?
Second. The car doesnt start well. When starting after its been sitting overnight, it takes a little extra cranking and then runs poorly for the first 1-2 seconds. It seems like this problem was a lot worse when it was colder out. Could this be a leaky injector? I have new nozzles to install. Will they likely fix this problem?
Dan
2000 Jetta 143kmi Stock-so far.
FOR SALE 2000 Golf GLS 237kmi
For Sale 1982 MB 240D 227kmi
2002 Ford Excursion Powerstroke 7.3 75kmi
whiterabbit7 is offline   Reply With Quote
Old March 17th, 2009, 15:27   #2
bluesmoker
bluesmoker's Avatar
Fuel Economy: 57 highway mpg
check your battery, it could be weak (not enough amps to run the glow plugs)
the glow plugs or harness could be bad, search the forums for "glow plugs"
2004 pd 5 speed tip,malone tuning stage 1.5 with egr delete
former:1998 red jetta 5 speed man, malone tuning stage 1 with egr delete (it still lives in Maple Ridge)
new gas guzzler: 2001 Mercedes Benz Ml 320
bluesmoker is offline   Reply With Quote
Old March 18th, 2009, 10:20   #3
whiterabbit7
The battery, glow plugs, harness, 180 relay, and 109 relay are all new. Glow had quit working before, but that problem has been fixed. From what I can tell this is not related to the glow plugs. This may take the best minds here.
Old March 24th, 2009, 11:06   #4
whiterabbit7
No help? Really?? I thought somebody out there would have some ideas.
Old March 24th, 2009, 11:16   #5
dieseldorf
top post dawg
dieseldorf's Avatar
Dan, do you have VAGCOM? Can you make some basic checks for DTCs and verify the coolant temp sensor is doing its job?
C&D magazine on the DSG:
Old March 24th, 2009, 12:42   #6
Traildog
What DD said:
VW programmed in a "flat spot" at 190* in the guage of @7 degrees either side of 190. I guess so that people wouldn't freak when the guage went over 190 climbing a hill and under 190 coasting down the other side. Your reading below 190 makes me think you're running substantially below that.
Since the CTsensor controls both the guage and the ecu:
A its bad, giving the guage faulty info, and possibly the ecu as well.
B its good, and you're running cold because the thermostat is sticking open. Your engine isn't running in its sweet spot either.
I'd replace the CTS first, and see if you read 190*. If the CTS was feeding erroneous info to the ecu as well, you may have solved both problems.
'96 B4V (orig owner), Shine susp w/ Bilstein ... '06 Jetta pkg2 DSG ...'99.5 Jetta ALH, VR6 springs, G60 clutch
'84 Jetta (spare parts FUN) 1.8 RD eng, knocksnsr ign conversion, match port A2 throttle body, Techtonics dwnpipe & exhaust, GTI / Boge gas susp
Traildog is offline   Reply With Quote
Old March 24th, 2009, 23:51   #7
whiterabbit7
The coolant temp sensor has been replaced. Because during the winter the glow plugs werent working and the car wouldnt start. I dont have access to VAG-com. Frank06 is about 45min away. I guess I'll have to go use his services. I need to get my new PP nozzles installed anyway.
What are DTCs?
Old March 25th, 2009, 07:01   #8
Traildog
Diagnostic Trouble Codes
Since the CTS is new, getting connected to Vag-com to read the actual temp as well as seeing what else is happening seems the next best step. Hopefully nothing serious.
Old March 25th, 2009, 07:32   #9
greengeeker
greengeeker's Avatar
Fuel Economy: 42.2/50.0/58.1
not getting up to temp: could be your thermostat is bad or your temp sensor is bad out of the box (happens a lot on the cheaper parts)
hard start: given the parts you already replaced I would think you have a small air leak in your fuel system, either injection pump or lines. Does your golf have a clear line inbetween the filter and IP? If so, watch it in the morning for large air bubbles.
- Nick -
02 Jetta TDI 340k (42.2/50.3/59.4 MPG) // 01 Eurovan 24V (18 MPG) // 00 TDI Ranger (39MPG)
How to Post Pics - How to Search
TDIclub trusted mechanic in Minnesota - PM me
greengeeker is offline   Reply With Quote
Old March 25th, 2009, 07:38   #10
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Hard starting and poor initial running could be timing too.
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old March 25th, 2009, 07:41   #11
mrGutWrench
mrGutWrench's Avatar
Fuel Economy: 63 MPG/56/47 (2nd tank) '02 Sedab
Originally Posted by greengeeker
not getting up to temp: could be your thermostat is bad or your temp sensor is bad out of the box (happens a lot on the cheaper parts) (snip)
__. Yes, that was my first thought. This just "feels like" temp sensor for both symptoms.
MrG, Wallace NC (2002 Jetta, Totalled by drunk, 11/'06; 130K mi in 4 1/2 years/~57 MPG lifetime); New car, '03 Jetta Wagon, CAT filter, .681 top gear, 350K mi. in 11 1/2 yr, ~52.
mrGutWrench is offline   Reply With Quote
Old March 25th, 2009, 07:42   #12
JASONP
JASONP's Avatar
Fuel Economy: 4.5l/100
Agreed Bob, had TB done and timing set correctly,before it was at 39-40 and now at 62-64 and cold start issues seem to have deminished.Still a little smokey.
2016 Jeep Wrangler, no longer do I have a diesel, repair manuals or spare parts sorry.
JASONP is offline   Reply With Quote
Old March 25th, 2009, 09:46   #13
whiterabbit7
Once I have started the car in the morning, the following start-ups are fine. But again the air temp is higher now than when the problems first started. So I was thinking along the lines of GreenGeeker, that there could be an air leak, or a leaky injector.
Old May 10th, 2009, 23:41   #14
MiniMan
Whiterabbit7, what was the cause?
'06 Jetta TDI
'93 Audi S4 - Uber modded
'09 Nissan GT-R
'08 Ducati 1098
MiniMan is offline   Reply With Quote
Old May 11th, 2009, 07:14   #15
MayorDJQ
What battery did you put in? Is it a proper rated 80aH?
MayorDJQ is offline   Reply With Quote
Page generated in 0.17744 seconds with 10 queries
[Output: 121.42 Kb. compressed to 100.00 Kb. by saving 21.42 Kb. (17.64%)]
