03tdiwagon
ok so here is my problem. I NEED A REPLY ASAP as i have t get my car on the road and order a new turbo if need be which will take a week to get!!!
i cleaned out my intake system to get rid of all the soot and when i took the turbo out for cleaning i found the housing was cracked and i was no longer going to reuse it. called my local supplier in Kitchener Ontario and he ordered me a factory replacement for the vnt15 aka the gt17v in modern day terms
today he calls me and says Garrett USA sent him a newer style turbo as the vnt15 is no longer made or remanufactured...... the label on the turbo says gt17v (which would be correct as a modern replacement BUT!!) the serial number on the box and number on the turbo don't match (both of them when I search Garrett website keep coming back with European models 88hp and 109hp units not the NA 90hp unit until the last page which says VW new beetle / tdi ALH 98-05 ?? 90hp but all golf and boras are saying 2006 year with either the 88 or 109 hp units.. i thought the alh was made in both markets until 03?? makes me not trust their website at all. this also doesnt make me trust there stamp saying gt17v as if they messed up the PN# what else could they of messed up.
the label does say made in the uk so i understand why these units are coming up but did they share the same turbo as the NA market??
GARRETT wesbite search
LINK ATTACHED.
https://installerconnect.garrettmot...07S&lang=en_US&utm_source=GarrettMotionSearch
below are the PN# SN# and turbo number on the box and on the unit
https://ibb.co/84B7Ppn
https://ibb.co/HnzjV7F
if you noticed the lst 4 digits on the box show 9007s, meanwhile the turbo shows 9006s...... you cannot find a 9006s on garrett pn search but the lnk i shared above is all from the 9007s??? SO MANY THINGS ARE INCONSISTENT
my id parts guy called Garrett said they said it is a replacement but didn't specify which unit is it the gt17v or the VA(gt17v) my parts guy calls it a gt7va which is slightly bigger turbine but same as a gt17, and then, of course, there is the larger gt17vb which im not using. i do not want to install this turbo and find out i need injectors or a tune to not starve the thing. can my factory intercooler handle is aswell if it is slightly larger turbo running hotter??
LINK ATTACHED.
