11-yr/162,000 mile warranty clarification needed
MyTDIRocks
New England
2012 Jetta TDI - Sold back to VW Snif :(
I just read the following in another thread: this quote was excerpted from an actual letter from VW to an owner of a 2015 vehicle:
The warranty period for the “Extended Emissions Warranty” limited warranty extension shall be the greater of:
 11 years or 162,000 miles, whichever occurs first, from the vehicle’s original in-service date; OR
 5 years or 60,000 miles, whichever occurs first, from the date and mileage of Phase 1 of the emissions modification.
I have a 2012 Jetta TDI that is eligible. I currently have 38K miles on it. Let's say I decide to get the fix and I have 40K miles at the time I get the fix.
Assuming I continue to put on an avg of 6500 miles/year, I would reach 162K miles over 18+ yrs or so (122K + 40K at time of fix), so in my case the 11 years occurs first.
If I calculate the # of miles from the modification, then the 5 yrs would come first since I put on so few miles.
Since the warranty is the greater of... am I correct in assuming that in my case, the "extended warranty" will be good for an additional 11 yrs of owning the car if I continue my current driving pattern?
KITEWAGON
Seacoast, NH
2014 Touareg Exec, 2014 JSW
Nope. You don't get an additional 11 years. You get 11 years total from the in service date. Or 5 years from the fix.
However I also think you're referencing the wrong warranty for a 2012. I believe the 11yr/162k applies to the new old sale 2015 cars. The older cars have a great warranty, but its a bit less in terms of years and mileage.
MyTDIRocks
New England
OK, I guess I'll have to find out exactly what the extended warranty on the 2012's is. Thanks!
BroncoAZ
Flagstaff, AZ
2015 Touareg Lux, 2015 Passat 6MT, 2009 Jetta (long gone), 2011 Touareg (bought back 02/18)
SkiBumJH
Jackson, Wyoming
2009 JSW, sold back 11/17, 2012 Jetta Sportwagen
Wow, 38k on a 2012... saw a 2013 on a lot the other day with just under 18k on it. Asking 15,700.
As I understand it, the 2015 warranty 5yr/60k part starts anew after the phase 2 work is done. Definitely a factor in your number crunching. 2015 warranty is much better as I see it.
