As the weather has turned colder I've encountered the following with my 2010 Jetta TDI sedan (has about 1,500 miles on it):
- On short(ish) trips, my fuel mileage has decreased. My commute is about 7 miles one-way, and when it was warmer I typically got about 38 mpg on my mixed city/highway path. With the colder weather, I'm now averaging about 33 mpg in similar traffic. I'm guessing this is temperature related as 1) the car is only just hitting normal operating temperature as I finish my commute, and 2) on 60 mile roundtrip freeway drive on this same tank of fuel I got the best mileage I've seen yet -- averaged just over 50mpg. (Mileage is based on the trip computer, which has proved to be pretty accurate when I calculate actual mileage after a refill.)
- I'm getting a low tire pressure warning. This started when it first dropped below 40 degrees and has been on constantly since. My tire pressures, checked with a good gage, were showing at 35-36psi when cold. I added about one PSI to each tire (so now all four are at 36-37psi) and the warning hasn't gone away. I'll keep experimenting with higher pressures, but is there any way for me to determine if I've got a bad sensor?
