pawel
- Joined
- Apr 19, 2008
- Location
- Naugatuck, CT
- TDI
- '09 TDI 6 MT, Platinum Gray Metallic, Anthracite Interior
Ok, I finally installed the LED tails.... and what a mess it was. Not only that I broke one of the wires, I couldn't get the terminals out of the passenger side connector... so I used the "cut the wire and connect" method... looks ghetto, but works. I all ready ordered new connectors with repair wires so that I can finish the job right...
Anyhow, now about the surprise. When I was done reconnecting of the connections, I decided to test the lights before I did any coding and... lights worked perfectly?? no "bulb out" light came on, the outer led's were blinking amber while inners one were red when brake was applied... both outer and inner leds were red with parking lights turned on. From what I have read, coding was required to get the amber turn feature. So did VW do something differently? Also, can someone tell my type of cecm this is?This is screen pic of CECM number.
