dkuster
I'm wondering if my battery might have become weak and that is what's causing my hard starting problem. My car is coming up on it's 2-year birthday. How long does the OEM battery last???
Check the grounds under your battery for corrosion. You should also check where the ground wire is attached to the engine block.Hmm, I figured 2 years was way too soon for a battery to
wear out.
Guess I need to look elsewhere to fix my hard starts.
Thanks for the replies.
That's about how mine went, except VW did NOT pay...99 NB I had the first replaced by VW after 2 years (they paid) and then replaced the second after 3 more.......not good
