Passanger Window Regulator
HBRD_KLR
Chicagoland
2013 Passat TDI SE 6M
Greetings
Short story short -
Driving from work today and close to home decided to open front windows, heard a loud crack from the passenger side - looked over thinking that window got shattered, but it just stopped going down. Tried to play with the switch to push it up but no avail. Upon coming home I was able to manually close the window. It's closed for now but with light push the window goes down.
I tried to look up Window Regulator for 2013 passat but the search pretty much came up with older VW model posts etc. At least it's what I think is wrong.
Just doing a RFI to anyone out there if this is a common problem (from searches it appears that it was with older VWs and how to fix it - i'm past 100k on the 2013 tdi and looking to probably try to fix it myself....
Much appreciated any constructive insight on above mentioned issue
