OCT 8, 2013 APR ECU for TDI is not ready!
CNNPress
Dallas, TX
12 Passat TDi
Hi all,
Two weeks ago I had my car flashed with APR stage 1. Shortly after, I got some error codes:
8848 - Torque Difference Cylinder 3
P1006 00 [032] - Limit Value Exceeded
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 34
Reset counter: 44
Mileage: 5523 km
Date: 2000.00.00
Time: 00:00:00
8849 - Torque Difference Cylinder 4
P1007 00 [044] - Limit Value Exceeded
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 3
Mileage: 33921 km
Date: 2018.14.21
Time: 07:08:57
_________________________________________
I cleared the errors, and had it run for another week. Last week I got 4 error codes:
8846 - Torque Difference Cylinder 1
P1004 00 [096] - Limit Value Exceeded
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 34
Reset counter: 104
Mileage: 8849 km
Date: 2008.10.07
Time: 22:00:00
P1006 00 [104] - Limit Value Exceeded
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Mileage: 34484 km
Date: 2018.14.28
Time: 15:44:31
P1007 00 [104] - Limit Value Exceeded
Freeze Frame:
Fault Priority: 2
Fault Frequency: 25
Mileage: 34469 km
Date: 2018.14.28
Time: 15:36:25
8847 - Torque Difference Cylinder 2
P1005 00 [096] - Limit Value Exceeded
Freeze Frame:
Fault Priority: 2
Fault Frequency: 25
Mileage: 34469 km
Date: 2018.14.28
Time: 15:36:25
__________________________________________
I then called APR today, and they told me they are working on those bugs, advice me to flash it back to stock for right now. They will work on the labor fee with me.
So, if you have a 12+ Passat TDI, the flash is NOT ready just yet. :(
Hope this info helps.
Jbratstdi
North Florida
2012 Passat SEL-Sold Diesel Gate
Tried to tell you...
My is done I have a 12 TDI cut APR some slack no problems errors I had it for almost 2 months now, I had a DSG flash from Malone and it may not have taken.
They will work out the bugs, I was told they have Dom much business from overseas right now that things are a little backed up.
LokiWolf
Richmond, VA
2013 Passat TDI SEL
Have you actually scanned your car? Not all codes throw a light...
Springfield, VA
Hopefully the digi one is out soon, no detection by the dealer scan
The Digi what? Tuning box? Any actual ECU data changes are detectable through the dealership's CHECKSUM scan.
LokiWolf
Richmond, VA
2013 Passat TDI SEL
You aren't even using the right name. The DIGI One is a serial to Ethernet interface device and has nothing to do with TDI. The Diesel Power DIGI CR I think is what you are talking about. I am not aware of any documentation that says that it will work on the CRKA motor found in our cars, or is going to be supported.
Also like V-TDI said it is nearly impossible to prevent it from leaving some kind of sign it was there. There is NO way it could plug into every sensor and intercept the signal.
If you are looking at APR, might I suggest Malone.
CNNPress
Dallas, TX
12 Passat TDi
Here is a newest update (beta V1.3) of the flash:
1) No more CEL codes
2) Speed limit is about 122~123mph
3) Much better response than stock ECU
4) Seems like transmision cannot keep up with the APR ECU flash, hesitation was noticed when suddenly speeding up.
The beta is not released to public. Please wait for APR to finalize the flash.
Hope this helps!
Eric
Springfield, VA
You're a trooper for continuing to beta test for them.
LokiWolf
Richmond, VA
2013 Passat TDI SEL
Hope this helps!
Eric
I agree, kudos for keeping up and testing for them!
Yet again I say, DSG Tune, DSG Tune, DSG Tune. There is no way the DSG can really keep up with the ECU tune without a tune itself...
Sent from my iPad using Tapatalk HD
CNNPress
Dallas, TX
12 Passat TDi
I agree! But since DSG tune will increase torque limit (the CEL codes I have seen many times in previous several flashes), in order to test APR tune, I won't be able to flash DSG at this moment. My goal is to test the APR flash with stock almost everything (no intake, no DSG flash).
Eric
