DCELL
frank- any word on the cinci thing? I looked and didn't see anything, but I didn't look too hard...
2001-down cars use a K-line electrical system while 2002-up are Can-bus based. They function the same but Can-bus involves less wires even if externally the harnesses and connectors may look the same. I have not run into connector compatibility issues - my power seats are from a 2000 in my 2002 but all connectors mated up perfectly. However I did have to change the control modules as those are specific to either K-line or Can-bus. Before I changed the module out I had some very weird warning lights / behavior occurring. Soon as I installed the proper module all worked perfectly. I tell you all this so you can check what you have swapped over from the 2.0 for modules - perhaps all you need are the 2002-up modules to make everything work properly. Hope this helps you out!SyntorX9000 said:Just wanted to say HELLO to everyone. I am new here. I live on the SE side of Indy, by Beech Grove. Bought the interior of a 2000 Jetta 2.0 and am trying to get it into my 2002 Jetta TDI....the plugs don't match up.
I have 10+ years in electronic "component level" repair, but I was hoping Murphy would keep his nose out of this one....no chance. Just doing the search thing-YIPPY!!
The turbo not the engine. I get my oil for free (505.01 PD) so the money for that is not a issue. The turbo will get replaced after the holidays. The oil consumption has leveled off and is predictable. Thats not good advice for me to give to anyone. Pull your lower intercooler pipe and if you have a lot of oil in the intercooler if so its your turbo.DCELL said:jerry- I talked to jharrison about your oil consumption. Unless it's dumping a big pool of oil under your car, or blowing oil all over the bottom of the car as you drive (indicating a bad leak) it's probably blown seals in your turbo. Sorry about the bad news, but he said his is sucking down a quart every tank or so and he'll probably just drive it that way 'till it blows up. I don't know if that's good advice or not, but its a possibility!
