compu_85
Gadget Guy
If you have the brake on does the outer light still flash? Does the center (bright) portion of the light come on when you hit the brake?
-J
-J
I went through my entire BCM controller today and made screen shots of all of the settings as is, including Byte 18. A0 is not an option to choose from in the drop down menu. Did you directly enter HEX A0 as Binary 10100000? Or is there some other method?I've got the coding back to A0 like you say it should be.
But when my parking lights are on, all 4 are at full brightness.
You can't see any difference in the turn signals, hazard, or brake lights.
I haven't installed the resistors on the inner lights yet, but that wouldn't change the brightness of the outer lights..
You are correct, A0 is not a valid selection on the drop down box.I went through my entire BCM controller today and made screen shots of all of the settings as is, including Byte 18. A0 is not an option to choose from in the drop down menu. Did you directly enter HEX A0 as Binary 10100000? Or is there some other method?
Anything would be better than the stock brake lights. Under certain lighting conditions (as with many incandescent rear lights), they are hardly visible. I found this out while following my wife driving the Passat in the middle of the day...the reflector quality of the surface of the light fixture just overwhelms the brake light.They're not as dazzling as my iPhone camera makes them out to be
But .... 4 brake lights has got to better than 2.
Right? Lol
As a point of reference, you can see they are approximately the same brightness as the CHMSL.
