The Turtle
- Joined
- Jul 24, 2006
- Location
- rural Maryland
- TDI
- 1996 B4 Passat wagon, SpeedTuning chip, 360,000+ miles, 1996 B4V, 306,000 miles on original engine
OK, I've searched and tried to find this, but where, physically, on the car is the expansion valve (capillary valve) on the AC on a 1996 B4? I have a system where the compressor is engaging, definitely has pressure in the lines, and the compressor is working, but produces no cold air nor any temp differential on the high/low tubes under the hood.
From longtime past experience, I am immediately suspicious of a clogged expansion valve.
Problem is, without lighting up the virtual machine so I can load my Windows-98-only Bentley CD, I can't find the thing. Where should I be looking? On my classic Saab 900s, it was under the hood. On my 240 Volvos, it was above the passenger's feet in the cabin.
Suggestions for hunting it down would be welcome. Yes, I have the 134a fittings and a lab-grade vacuum pump. Just need to find the spritz valve.
