Is it possible to use your needle adjusting technique to make the speedo correct? lose 4MPH instead of gain 150 KPH? Got a link or description of the process?
yes, its very easy. simple take the cluster apart, and rotate the needle counterclockwise until you get a perfect 0 reading. dont worry you wont break it, but there will be some resistance. this is also the same procedure for removing the needles.
so you would rotate it 1 full position. if you have a vag-com, simply run output tests on the cluster, once the speedo shows a perfect 100km/h, its perfectly set.
Mine ('96 Passat TDI) did something by itself today. It re-zeroed itself at about 65mph and is idling at about 5500rpm. The dealer says something about servos and circuit boards requiring a replacement of the entire instrument panel. I'm going to try rebooting first, but if that doesn't do it, any suggestions?
