Nope, have never ever had that problem.
Our 98 NB has a non O-ring Bosch fuel filter, ie t the fuel filter does not have a removable inlet port on top, it is one soild fuel filter and has no chance of leaking unless you forget to tighten the drain on the bottom of it. Adter four changes of the fuel filter every 20,000, still no hassles at all with it.
Our 99 Jetti does have the Bosch O-ring fuel filter, but it still has the original OEM O-ring that came with it even after three 20,000 mile fuel filter changes, I never even bothered to change out the original O-ring after three years since it still works perfect. No leaks, no hassles whatsoever.
How or why does this keep on happening again to you?
