you can see the box in the picture of the side load heater, part number on their site is 35160. and the filter was part #33642.Windowlicker said:Any chance you can get us the part numbers off those parts you ordered from RI?
enjoy.
as described on Reliable Industries site,homebrewtdi said:On numerous occasions, I've left it on (accidentally) for hours and hours with seemingly no ill effects on the battery.
meaning, you'll never have to worry about draining the battery. the heater shut itself off when the fuel got warm enough, both when you're driving and when your shut down and go inside for the night. that is an excellent feature to help keep the fuel from getting too hot, or from draining the battery.Reliable Industries site said:A simple and reliable sensor reacts to the fuel temperature and, when needed, activates a high-efficiency heating element.
I wouldn't say you never have to worry. If you leave your car parked for extended periods, even a month or a few weeks in the winter. I would think your battery would be drained.MrErlo said:as described on Reliable Industries site,
best information available from their site ismilehighassassin said:Also, that quote is for the top mount heater, have we determined 100% if the side mount operates in that manner?
i have to believe that means that it also have a thermostatic shut off switch. the VeggieTherm has one, seems reasonable that this type of heater would have one also.The Side Load Heater option (12 or 24 volt, 100 watt) is designed for use in conjuction with the hand or electric pumps, providing all the capabilities and benefits of the In-Unit Heater.
Do the research from the original threads. You CAN get a a 2 micron Stanadyne filter, but the 5-micron filter is 93% effective at removing 2-micron sized material from the fuel, that is at 45 GPH, where the TDI pumps 18 gallons per hour, so the efficiency rating on our cars would be even higher than the stated 93%mtogburn said:Hello Guys,
Alright somebody help me out with this. I was getting ready to do the cat filter that other TDI guys have mention but they were talking about 2 micron absolute. Somewhere in here I read this filter was 5 micron. So I am guessing this will catch more of the crap in the fuel. So will this setup fit into a 96 Passat B4? The vehicles in this thread don't look the same under the hood as the passat I just got. Can I use this setup? And is it better than the Cat setup? Thanks Mike
Interesting setup. Is that a restriction gauge on your setup? Where in-line is it being measured?steakman said:Very interesting thread. At this time I'm not a TDI owner...but am in the hunt for an 2001-2003 Jetta handshaker.
Currently running a Duramax and I too have istalled this filter system. Biggest issue I faced was what to do when the fuel got a bit cloudy at -26C (I was using a BioD additive), and couldn't bypass the 5Mu filter.
http://inlinethumb28.webshots.com/19995/2276368900047245006S500x500Q85.jpg
http://inlinethumb12.webshots.com/33867/2929597300047245006S500x500Q85.jpg
The bypass was the result of not being able to buy a new 5 Mu filter over this particular weekend..and it gave me something to do while staying away from the feud.! so now at least if my filter plugs during winte, I can just turn the valves and run direct. (note I still use the OEM fuel filter too, the FM is post OEM). Typically get about 35,000 km before it needs to be changed)
Cheers,
stk
i highly recommend the FM-100 side-mount heater to TDI owners, although since your setup is slightly different you might want to check out the in-unit heater.steakman said:Currently running a Duramax and I too have istalled this filter system. Biggest issue I faced was what to do when the fuel got a bit cloudy at -26C (I was using a BioD additive), and couldn't bypass the 5Mu filter.
i haven't heard anything about it not working horizontally.. that's odd. well, we'll find out soon...vwlogue said:That's the same one I was going to order, but Tim the seller said it wouldn't work if horizontally mounted, unless I empty the oil, which would make the drag pointer more sensitive to vibration. I guess I'll just give it a try.
that's definitely overkill - and quite possibly too restrictive. stanadyne has a 2u filter as well. the 5u filter however already filters out 92-93% of 2u particles. if you want absolute 2u filtration, get the 2u filter and just use a simple inline pre-filter like the MANN or something else that will get larger particles, but not cause too much restriction.VDubsoon said:OK, I and getting ready for my fuel filter upgrade and have a few questions on mounting. I looked for the best spot while installing my DG Oil bypass filter and came up with a spot next to the battery as the deepest and widest. My goal is to install the FM-100 and run a 30u filter in conjunction with a 2u CAT. Overkill, maybe. My thought is to mount plates on the inside and outside of the battery box to provide support. Otherwisde I could fashion a U-shape mount and tie it in to the front of the engine bay. Any thougths would be greatly appreciated.
the FM-100 has a 2u option as Pods just pointed out. in fact, i have a 2u 4.3" element at my place right now. i bought it by mistake before i read the restriction numbers from SUNRG.VDubsoon said:PD lift pump will be added to deal alleviate restriction, so that won't be an issue.
I like the water separation of the FM-100 (thougth I have heard mixed reviews) and the 2u capability of the CAT. I also figure this will afford me extremly intervals between filter changes.
i don't have the restriction numbers for either the FM-100 or the Cat 2u filters, i believe you'll need to contact SUNRG to get those numbers. they have been posted in a thread, but i can't remember where.VDubsoon said:OK, so is the 2u, 6" FM-100 too restrictive for use with lift pump on ALH?
Nice pics on the turbo instal.burpod said:today i changed my fuel filter (been about 30k miles) and re-located the fm100 to the location as kwgilpin did, except i kept the standard direction of the fm100 (not sure if it makes a difference). in order to do this i cut off and buffed the fm100 head mount. much nicer in this location!! wish i had thought of this before. less hose, just as easy to service and now i can install a dieselgeek bypass filter next oil change. i'll have some better daytime pics of the install tomorrow. i also installed the fuel restriction gauge and removed the clear bowl water separator (since there is no room for it here)...
photos start here and go to the right (to the left is turbo install!!! ))
http://picasaweb.google.com/burpod/TurboInstall/photo#5227522592504662242
