Radiators and condensers are not high failure items. More times than not, crash damage is what causes a need for replacing them.
Some day, if you are bored and have the time, you can take the front bumper cover off, support the radiator/condenser/fan assembly (leave all the hoses and lines attached), unbolt the lock carrier assembly and slide it straight OFF the car, headlamps along with it, and then you can blow out with compressed air and a blow gun the space between the radiator and condenser. There will be a lot of build up of filth in there especially if the car has covered 300k+ miles.
Also a good time to completely remove the front fender liners and clean out under them, and if you haven't already, trim or remove the stupid rust causing foam blocks under the fender lip.
Note: NBs are a little more involved, but certainly not hard. If you can replace a headlight bulb, you can R&R the NB's front clip, as getting the headlamp assemblies out is literally the most difficult part.
