Still working on the NB project. The connectors to the coolant glow plugs are in horrible shape. Does anyone know if they are available? Part number perhaps? Rather go new than used.....
In a pinch you could neatly solder the wire directly to the GP lug and cap with a wire nut or dab of silicone sealer. Not exactly professionl, but it will work. Or you could slip some heat shrink tubing over the wire before soldering and slide the tubing piece over the solder joint and shrink it down. That would probably be the neatest looking.
