Old February 10th, 2019, 10:50   #136
turbobrick240
turbobrick240's Avatar
That sure does sound like a fantastic TT swap/build. Interesting info about the KNS code 02Q. They may not have the uber tall 6th gear, but that might be another plus in a sports car.
Old February 10th, 2019, 21:57   #137
ATR
ATR's Avatar
Thought I'd share a bit of info that I've found having owned 2 MK7 Golfs (GTI before and now a R)...
Sachs offers a 4 puck racing clutch that can hold a absurd amount of torque (568 ft-lbs). And here's the cool part: You can still use the OEM style dual mass flywheel. Friend of mine has this setup in his hybrid turbo GTI and it's holding the power just fine. Link the this clutch is below. I don't know if it's compatible with the TDI or not.
Clutch
https://www.fcpeuro.com/products/vw-...genuine-vw-kit
Drivers Wanted
-2011 Golf TDI 6MT = gone but not forgotten!
-2017 Golf GTI Sport 6MT
***Official maintenance schedule for your VW [PDFs inside]***
ATR is offline   Reply With Quote
Old February 10th, 2019, 22:01   #138
ATR
ATR's Avatar
Update to my last post... the clutch that I listed doesn't look like it would fit.
Same clutch but for the TDI should fit:
https://www.fcpeuro.com/products/clu...e-881864999505
You'd also need the corresponding pressure plate:
https://www.fcpeuro.com/products/pre...e-883082001422
so it looks like the friction disk is the same between the kits, but from what I could find the pressure plate is different.
Drivers Wanted
Old February 11th, 2019, 08:52   #139
Bigtoy302
My TT is lifted and has 215/65/16 Geolanders on it so the shorter 6th will be perfect.
Bigtoy302 is offline   Reply With Quote
Old February 11th, 2019, 10:21   #140
adjat84th
adjat84th's Avatar
Fuel Economy: ~50 in mixed driving
The Sachs SRE from Darkside is what I have. They offer a sintered disc (I think it's 4 puck) that holds insane torque as well, but I wonder how harsh it is in daily driving. That's why I went organic.
Sent from my Pixel 2 using Tapatalk
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTD1752vrk, 4bar MAP, CP3, Peloquin LSD, Sachs SRE w/DMF, Fluidampr
adjat84th is offline   Reply With Quote
Old February 11th, 2019, 12:23   #141
jason_
I've used a 4 Puck, not in a tdi, and it wasn't too unpleasant.
It's no city setup, even for those that are quite handy with a clutch..in my opinion.
But I'm a guy that really doesn't like high rpm when taking off. Combining that with low rpm engagement with a Puck setup id imagine it's more difficult.
My old 09 I had a terrible terrible tendency to gag the rpms so low the ecm would kill fuel once below 500rpm.
I had to break that habit at least for that car. 750-1k rpm I was easily scuffing rubber from stand stills.
Sent from my 2PS64 using Tapatalk
jason_ is offline   Reply With Quote
Old February 11th, 2019, 22:18   #142
ATR
ATR's Avatar
Just checked and it looks to be a similar if not the same disk.
Knowing that Darkside offers the kits and likely know for sure what works and doesn't. I would just go with them for a clutch.
Also, the 4 puck initially (before break in) is a bit harsh. But after break in it's pretty decent and certainly livable on a daily basis.
Drivers Wanted
Will Mk7 Golf wheels fit a Mk4 Golf? ROD-TDI Upgrades (non TDI Engine related) 3 February 28th, 2015 11:32
Page generated in 0.14874 seconds with 12 queries
[Output: 84.99 Kb. compressed to 73.87 Kb. by saving 11.12 Kb. (13.08%)]
