Old June 12th, 2019, 14:21   #1
thundershorts
Default led dynamic tail lights
Has anyone found any of these nifty tail lights of decent quality at a reasonable price, 300-400?
"You can't argue with a fool..."
thundershorts is offline   Reply With Quote
Old June 13th, 2019, 23:35   #2
Nuje
Ed's is about the best I've found. Not in your price range, mind you - but top-notch seller.
https://www.becautoparts.com/collect...=8119002497138
His ride: 2015 GSW SEL TDI with MIB2, Active Info Display, Adaptive Cruise retrofit
Her ride: 2016 A3 e-tron
His other ride: 2015 Giant Propel SL Di2
Nuje is offline   Reply With Quote
Old June 14th, 2019, 08:48   #3
thundershorts
Seller assumes all responsibility for this listing. look about the same: ebay 323178630427
Old June 14th, 2019, 08:53   #4
Nuje
Yep...which looks about the same as this one at Aliexpress.
(Guess where they all buy them from...)
Old June 14th, 2019, 12:46   #5
adjat84th
adjat84th's Avatar
These looks amazing! I think I may just have to pick up a pair.
Edit: I usually don't impulse buy, but I just ordered a pair!
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTB2260vklr, CP3, Peloquin LSD, Sachs SRE w/DMF, Fluidampr
Old June 14th, 2019, 14:05   #6
Nuje
My experience with Ed has been fantastic - I'm sure you'll love 'em!
(I'd have a set myself, but - and he confirmed that he's tried to fit them - sadly, they do not fit the Mk7 Sportwagen. )
Old June 21st, 2019, 00:23   #7
Mike in Anchorage
Mike in Anchorage's Avatar
If you find some cool ones with yellow turn signal, preferably sequential, I'm listening.
Also, new Chevy's have a high mojnt brake light that quickly flashes three times when the brakes are applied. The lower lights do not flash - only the high mount light does this. I wonder if that's am easy install. Anyone else notice and want it?
~ I'm selfish, impatient and a little insecure. I make mistakes, I am out of control and at times hard to handle. But if you can't handle me at my worst, then you sure as hell don't deserve me at my best.” Marilyn Monroe
2015 Tornado Red Golf TDI Sportwagen SE, new on 2 SEP 2017, DSG, big sunroof. Lovin it!
Mike in Anchorage is offline   Reply With Quote
Old June 21st, 2019, 04:57   #8
thundershorts
ed seems to be having a price reduction right now check out his site and the videos there.
Old June 21st, 2019, 07:59   #9
adjat84th
adjat84th's Avatar
Is that something that can be changed in VCDS?
I know you can enable the emergency flashing, but feel this is in there somewhere too. I'd definitely like that.
Old June 21st, 2019, 08:52   #10
Nuje
DV52, are you there? Paging DV52...
(He's the wizard of all things to do with the "Central Convenience" module and fiddling with the lights in particular).
Edit:
Dug out his über-thorough Excel sheet of ALL the lighting functions (a mere 2385 adaptation channels) in the car that he compiled. He put it together to compare the function of each light (and thus setting) across the VW's various markets (e.g., NAR, RoW, Australia (he's Australian), etc.).
All of which is pre-amble to: Within VCDS - Central Convenience (9) - Adaptations (you probably have to enter the "security access" code first...I think it's 20103 - either that or 31347), and then do a search for Leuchte22BR MA57 - that's the third brake light...i'd think that if that mod was possible, this is where it'd be configurable.
(And puh-leeeze...make a backup of your adaptation channels and log your changes, just in case...)
Old June 21st, 2019, 12:05   #11
Nuje
https://www.bks-tuning.com/oem-euro-...-facelift.html
After seeing that price, are you still listening...?
Old June 21st, 2019, 14:43   #12
adjat84th
adjat84th's Avatar
Received the lights today from BEC, didn't realize I would have to run a little wiring from each connector up through the paneling. No big deal, but need a half day to install now, so hopefully next weekend I'll have enough time for this!
Old June 21st, 2019, 15:23   #13
thundershorts
Did the harnesses come with the lights or were they extra cost?
Old June 21st, 2019, 15:33   #14
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Why spend $500+ on something that you, as the driver of the car, will NEVER SEE?
-George Bernard Shaw
Old June 21st, 2019, 16:17   #15
Nuje
Why does the multi-zillion-dollar women's cosmetics business exist...?
LED tail lights and reverse lights 2011 TDI Upgrades (non TDI Engine related) 5 June 11th, 2016 05:44
2010-11 Projector Headlights, LED Tail lights & HID fog lights for sale! DUDA Private TDI Items for Sale/Wanted 7 December 16th, 2011 04:35
LED tail lights jasman19 Upgrades (non TDI Engine related) 9 August 30th, 2008 18:44
LED Tail Lights..... ZIG TDI VW MKV-A5 Golf/Jettas 1 June 8th, 2008 15:40
LED's For Tail lights AUGSX Upgrades (non TDI Engine related) 4 April 21st, 2008 18:13
© 1996 - 2020, All Rights Reserved
Page generated in 0.19008 seconds with 11 queries
[Output: 134.02 Kb. compressed to 112.15 Kb. by saving 21.87 Kb. (16.32%)]
