Old June 7th, 2019, 18:41   #1
nathanso
nathanso's Avatar
Default GSW Suspension Upgrades
I'm considering the H&R Sport Springs and Koni Special Active shocks for my 2015 GSW TDI S and would appreciate hearing comments from anyone here who has actually done this and can comment on ride quality and performance vs stock.
nathanso is offline   Reply With Quote
Old June 8th, 2019, 11:43   #2
CrazyMonkey
I have the H&R Sport springs with the factory dampers. The ride is definitely firmer and body control is much better in corners and braking. I think it's an improvement. It feels more like a GTI, maybe a little stiffer. It's hard to say exactly since it had been a little while since I had driven a GTI.
I like the stance much better too... I didn't want to dump it since I hit the occasional gravel road for mountain biking and such, just get rid of some of the tire gap along with the aforementioned increase in spring rate.
Before:
After:
Then after putting on a set of SEL wheels:
CrazyMonkey is offline   Reply With Quote
Old June 9th, 2019, 09:17   #3
nathanso
nathanso's Avatar
Looks good! Did you happen to measure the amount of lowering the change caused? Are you experiencing undue scraping of the low parts of the car?
Re the shocks, last year I put a set (F+R) of Koni FSD's on a Volvo V70 that I recently sold. As near as I can tell, apart from a color change from gold to red, the Special Active Konis are the same shock as the FSD's. In any event, I liked the FSD's. Not overly stiff; just a well-controlled ride. Special Active shocks for the GSW seem to be newly introduced to the market so perhaps it's too soon to expect anyone here to have them on their car.
Old June 11th, 2019, 07:08   #4
CrazyMonkey
I didn't measure, but according to H&R, it lowers the car by about 1.5" and that seems about right. I have to be careful pulling up to a curb or a concrete wheel stop in a parking lot. The chin is low enough it will hit most of the wheel stops, so I just make sure I don't pull up far enough to hit them. I haven't had any scraping leaving parking lots or anything, but I just make sure I'm careful of the angle on the steeper ones. There's a ferry nearby with a steep entrance on one side and I am not going to attempt that... my wife's stock Nissan Maxima scraped on that... I have bottomed out the underside on an extraordinarily-large speed bump one time in a parking lot in another city. I'm used to driving lowered cars, usually lower than this one, so I just know where to be careful.
Eventually I will upgrade the dampers, but that's a ways out yet. I'm also seriously considering Neuspeed's front and rear sway bars. I just haven't pulled the trigger yet.
Old June 11th, 2019, 10:21   #5
mkane
TDI(s): GSW SEL 6spd
Any part #'s for the SA shocks? Hard to find
mkane is offline   Reply With Quote
Old June 11th, 2019, 10:29   #6
AGOODHI
i have them with stock shocks. what i don't like is my car doesn't sit level. the rear has slightly more wheel well gap. car is more planted in turns though, but if you push it hard, you'll easily reach the limits of the stock dampers. you definitely have to be more careful over speed bumps and when parking. i've driven lowered cars before, so i knew what to expect.
2015 GSW SE (new 60 miles) | Black | DSG | Bi-Xenon | Pano | Fender | Madico Onyx Tint | Ceramic Pro | deAutoKey LEDs | H&R Sport Springs
AGOODHI is offline   Reply With Quote
Old June 11th, 2019, 10:39   #7
mkane
Special Active Shock #8745-1324f & #8245-1326r
Old June 26th, 2019, 09:15   #8
nathanso
nathanso's Avatar
The H&R Sport Springs drop the car more than I'd like considering the deplorable state of our roads here in Norcal. I'm hoping that somebody one day works out how to install GTI or Audi springs/appropriate pads that work with the Mk7 GSW TDI. This would provide an economical solution since such parts are generally available cheap as low mileage take-offs. Ideally, for me, the drop would be in the sub-1" range and the ride moderately sportier without being bone-jarring. The shocks are the easy part, i.e. the Koni Special Actives as previously mentioned below.
Old June 26th, 2019, 09:40   #9
CheapBastard
CheapBastard's Avatar
TDI(s): 2014 JSW
Fuel Economy: 30
Dropped my 2014 Jetta wagen on Sports with KYB G2 on the rear and Gabrielís up front, ride is almost like stock but stiffer and just a touch bouncy over large bumps at highway speeds.
Got the same springs on my Ď14 Passat with bilsteins up front and KYB on the rear and itís much bouncier, not sure if itís a heavier car or the different struts up front or the 18ís vs 16ís on the wagen but the wagen feels very close to stock
CheapBastard is offline   Reply With Quote
Old June 27th, 2019, 19:00   #10
laminated
I did sports on my Passat, took em out a couple weeks later, unless you have smooth roads the novelty wears thin.. I added the rear sway bar to my GSW. like it. if I want more cornering I add 2-3 more psi to the tires.
laminated is online now   Reply With Quote
GSW Front Suspension Damping The Tortoise VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 0 February 19th, 2019 12:19
Battery upgrades for 2015 GSW? TDI4evah VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 16 February 12th, 2018 03:55
Suspension and wheel changes on 2015 GSW Ernie VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 10 May 7th, 2017 17:55
suspension upgrades yosemitesamiam VW MKIV-A4 TDIs (VE and PD) 15 June 2nd, 2004 20:48
Suspension upgrades.. christoff TDI Power Enhancements 4 November 13th, 2002 20:05
© 1996 - 2020, All Rights Reserved
Page generated in 0.16834 seconds with 11 queries
[Output: 97.01 Kb. compressed to 82.63 Kb. by saving 14.38 Kb. (14.82%)]
