Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > Audi SUVs (Q7 & Q5) and other V6 TDIs
Audi SUVs (Q7 & Q5) and other V6 TDIs Discussions area for Audi Q7 and Q5 TDI (2009+ in Canada & the US) as well as others with the V6 TDI such as the A6, A7 and A8 sedans.
Old March 26th, 2019, 08:01   #1
mswanson65
Default MAF Connector
Ya, so I was changing my air filter yesterday on my 2015 Q5 TDI, after putting the new filter on I was trying to push the air intake/maf pipe back into the mouth of the filter housing and I stupidly was pulling on the MAF electrical connector and cracked the connector. So I call the dealer and they said I need connector part# 4F0-973-705 even though my old connector is part#3AA-973-705. It looks like only 3 wires of the 5 pin connector are used. On mine it is Pin #1 - green wire, Pin #2 - Brown, Pin #3 - purple. They don't sell this connector as a pig tail. You have to buy a repair wire(s) that has connectors/seals at both ends and is meant to be cut in half to repair to pins. The connector was only $8 but the repair wires are $40!!! So long story short be careful pulling on this pipe when changing air filter. Any other ideas would be welcome. they have some on Ebay but I want to get my car going asap. Thanks!
mswanson65 is offline   Reply With Quote
Old March 26th, 2019, 09:56   #2
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Some of the repair wires are gold plated, which is why they are so expensive, FYI. If the part number ends in 'EA' that means gold plated. I cannot say for sure if the MAF connection necessarily requires this, though.
The '3AA' and '4F0' are two sides of the same thing, male/female.
The harness side should be the 4F0 one. If in doubt, do a google image search with the part number and you should be able to find a picture. ETKA has nice color pictures too.
oilhammer
www.cardocautomotive.com
Old March 26th, 2019, 10:22   #3
mswanson65
Thanks for the info. I had googled the 3AA and the 4F0 connectors and they looked similar except that keyed notch is swapped. On the 3AA which is what I have the keyed notch is on the side without the lock. On the 4F0 the keyed notch is on the side that has the locking mechanism. And surprisingly that agrees with what I have currently on the MAF (or is it MAP for TDI) side where it has the keyed notch on the same side as it has a step for the locking mechanism to grab. Not sure how the 3AA was staying on, maybe just the rubber seal holding it in place. Wish this wasn't all such a mystery. I suppose if I had the online manuals it would be easier to decipher... lol
MAF CONNECTOR - Contacts & Connector wire/contact necessary? fabed23 VW MKIV-A4 TDIs (VE and PD) 1 May 10th, 2012 10:12
connector MAF geojetta VW MKIV-A4 TDIs (VE and PD) 1 March 1st, 2011 14:47
MAF Connector geojetta VW MKIV-A4 TDIs (VE and PD) 0 November 4th, 2007 13:54
MAF Connector Draza VW MKIV-A4 TDIs (VE and PD) 7 October 5th, 2005 08:41
MAF Connector Mike Piles VW MKIV-A4 TDIs (VE and PD) 6 August 24th, 2002 00:30
Page generated in 0.12822 seconds with 11 queries
[Output: 58.81 Kb. compressed to 53.54 Kb. by saving 5.27 Kb. (8.97%)]
