Old August 9th, 2018, 14:42   #1
2015GSW
Fuel Economy: 38-42
Default infotainment display issue
Yesterday the infotainment screen in my 2015 Golf Sportwagen went black. The "brains" in the glove box still work, for example I can play a CD. The touchscreen responds to touches, but since the screen is all black I have to guess where the buttons would be. I have owned the car for less than 4 months. The infotainment screen worked a few days ago although the display would often flicker with ghost images. The 36 month bumper to bumper warranty just ended a few days ago, so I missed my chance for a free repair.
I tried holding down the power button for 15 seconds many times. I hear a little crackle after 13 seconds but nothing else happens. My guess is the backlight to the touchscreen has failed. I had electrical and radio gremlins with past VWs. I made an appointment with a local VW dealer for next Tuesday. I gave the service guy my VIN and he told me the warranty just expired but he said we could work something out which might mean a discount on the service.
I started to take the trim pieces off around the touchscreen after watching a YouTube video, but the clips are on pretty tight and I don't want to break the trim plastic. Should I try to put an aftermarket touchscreen radio in or fix the factory infotainment? Are other Mk7 golf owners having issues with their touchscreens?
2015GSW is offline   Reply With Quote
Old August 9th, 2018, 15:12   #2
1854sailor
Resident Curmudgeon
1854sailor's Avatar
The only issue that I've had with our display screen is some flickering when the back-up camera is on. Couldn't make it happen the last time the car was in for service, but the dealer is aware. Luckily, ours is a CPO with the 2 year unlimited mileage warranty.
-George Bernard Shaw
Old August 10th, 2018, 05:39   #3
GreenLantern_TDI
GreenLantern_TDI's Avatar
Fuel Economy: Mid 40s
In reverse the screen will go blank if car moves over 4 mph. Like all electrical try cycling the power and see if it does come out of it.
2015 Golf SEL. Malone Stage 2 and DSG Tune. H6 AGM East Penn Battery. Frost Heater. Ares Skid Plate. Fumoto Valve. PentoIII.
GreenLantern_TDI is offline   Reply With Quote
Old August 10th, 2018, 06:41   #4
1854sailor
Resident Curmudgeon
1854sailor's Avatar
I doubt that I ever drive over 4 MPH in reverse, and it sometimes flickers even with the car sitting still. It's actually more of a pixillation than an on-and-off flicker.
Old August 10th, 2018, 08:32   #5
2015GSW
Fuel Economy: 38-42
I disconnected the battery for a hour but the screen is still blank. I think it's the backlight because the touchscreen still responds. I could buy a used 5G0919605 from eBay for $100 but I would still have to get the dealer to unlock it and maybe they would refuse to. There is some kind of anti-theft called CP so I can't just swap another display unit without unlocking it.
Old August 10th, 2018, 10:29   #6
sportwagen3
I have my old display (5G0 919 605H) since I did the MIB2 upgrade if you want. Just PM me if you're interested in buying it off me.
Last edited by sportwagen3; August 10th, 2018 at 10:32. Reason: Added the display part #
sportwagen3 is offline   Reply With Quote
Old August 10th, 2018, 10:56   #7
2015GSW
Fuel Economy: 38-42
Thanks for the offer. The dealer service guy said I am so close to the end of the warranty that they are going to replace it for "good will" and he told me not to buy anything.
Old August 16th, 2018, 11:42   #8
360gtracer
360gtracer's Avatar
I know I'm late to this party, but that's exactly what I was going to suggest you push for. Glad they offered it for you.
George P.
Central VA
'04 J Wagon - now owned by friend, 255K+ miles!
'15 GSW - blue/beige/6sp - 30K/yr, avg ~50mpg
'12 Passat SEL - Ti/Nav/DSG - used w/ 72K miles
360gtracer is offline   Reply With Quote
Old August 16th, 2018, 11:58   #9
aditud
Any updates? Did they figure it out?
aditud is offline   Reply With Quote
Old August 16th, 2018, 16:40   #10
2015GSW
Fuel Economy: 38-42
Smile They replaced 5G0035878AU with 5G0035878AX for free
I just got it back from the Cutrubus dealer in Layton Utah. They fixed it for free as a good will repair. I asked the service advisor if these units are glitchy and she said somewhat, mine was the third one the dealer has replaced in the 2015 models. The service advisor Ashlei claimed they saved me almost $1000 by repairing it for free. The 5G0035878AX control unit which they installed is a $400 part while the 5G0035878AU which they removed is a $150 part. I think it's just a revision of the same part which is the CD player and "brains" in the glove box. The new unit should last 5+ years and by then we can expect better or cheaper aftermarket options.
Here are the service notes from the invoice:
Installed 5G0035878AX CTRL unit Qty 1
Core Chg 5G0035878AU CTRL unit Qty 1
Verified that radio has sound but screen does not work. Checked fault codes using GFF and found fault for B1297F6 multimedia display wire open circuit. Removed trim and display unit/radio and display is ok. Removed ECM for information control head and checked wires between ECM and display and all are ok. Replaced and coded ECM for information display control head and now display works properly. Cleared all faults and reinstalled center dash trim. Good will repair per service manager. $0
Old August 16th, 2018, 18:42   #11
RIP TDI
I believe the "X" suffix in VW p/ns normally indicates the part is a reconditioned, not new or a redesigned part. The core charge seems consistent with that.
- Chris
'15 GSW SE 6MT, '01 Golf 5MT
'97 Passat sedan, '96 Passat variant
'99 BMW M3 Cabrio
RIP TDI is offline   Reply With Quote
Old August 20th, 2018, 14:43   #12
2015GSW
Fuel Economy: 38-42
When I google 5G0035878AX the results show a $400 part and when I google 5G0035878AU the results show a $150 part. I don't know how they program the ECM or the CP to accept the new part when they swap it.
Old August 21st, 2018, 06:50   #13
RIP TDI
If I'm right and the X part is an unimproved, reconditioned U part, no recoding may be necessary. And the $400 price would not reflect the core credit. The availability of the X part suggests the U is no longer available, regardless of whether its still listed.
- Chris
'99 BMW M3 Cabrio
Old March 1st, 2019, 05:53   #14
finkadelic
Just wanted to add that i experienced a flickering screen issue in my 2015 sportwagen tdi s. I found a replacement control unit (glovebox) on ebay pretty cheap. Foolishly didn't realize that it would be locked out for theft prevention. Took it to the dealer and they unlocked for about $70. Works great, glitching gone.
finkadelic is offline   Reply With Quote
Old May 30th, 2019, 19:00   #15
Jedadiah
Jedadiah's Avatar
My screen went black this week. If I knew where to press, the touch screen still functions. It just has no backlight, I guess. I have an appointment Monday, since I'm still in my 3 year warranty period. I'll scan the car before my appointment to see if any error codes are present. I wonder how common this failure is.
Jedadiah is offline   Reply With Quote
RNS 510 DIsplay issue? physicshogon VW Passat Family (NMS and B7) TDIs (2012+) 9 July 17th, 2012 10:46
mildly annoying user quota display issue etag1949 TDIClub and TDIClub Forum News, Issues, Problems and Suggestions 2 November 24th, 2010 11:08
MFD display add on screens? like remote display for radar detector? PlaneJob VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 2 April 30th, 2010 06:16
LCD display issue OriginalSterm TDI 101 3 September 6th, 2008 10:03
OBD Info on Climatronic Display (AirCondicioning display) manuSpain VW MKIV-A4 TDIs (VE and PD) 0 May 28th, 2001 14:24
Page generated in 0.17606 seconds with 11 queries
[Output: 128.06 Kb. compressed to 106.69 Kb. by saving 21.38 Kb. (16.69%)]
