Old January 6th, 2018, 16:01   #1
PHAT-DUB
PHAT-DUB's Avatar
Default MK7 - DIY thread
Not sure if there is a DIY thread in here but thought maybe we could start one so it makes it easier to find things instead of having to browse through bunch of "what did you do to your ..." threads.
I will try and keep it updated in a list format perhaps we can make this a sticky. please feel free to add on.
Social media Groups:
VW Alltrack & Sportwagen Kollektiv
VW vortex DIY:
VWvortex MK7 golf/GTI DIY thread
VCDS Tweaks:
VCDS tweaks for Golf R vwvortex page
VCDS tweaks from VWwatercooled page
Radio headunit settings while in motion
Engine:
EA288 oil change
Lighting & Electrical:
Battery - Larger Battery retrofit
Fuse - Adding fuse circuits to the inside inside fuse panel
Retro-fit lower door red/white warning/puddle lights
Interior:
MK7 frameless autodimming homelink mirror retrofit
Right side passenger under seat drawer
Full-size spare tire with subwoofer
Exterior:
Rear hatch window side spoiler fin retrofit for wagons another rear hatch window side spoiler link from tdiclub
Rubber oem jack pads
OEM retro-fit skid trays, aerodynamic under trays & stone guards for IRS
Pano roof leak - drain hose end plug removal
Suspension & Brakes:
288mm to 312mm Brake swap
Towing
Westfalia hitch and wiring install by Jedadiah
http://forums.tdiclub.com/showthread.php?t=487951
http://forums.tdiclub.com/showthread.php?t=446936
www.badgeskins.com
Custom MK4 widebody for sale - here
PHAT-DUB is offline   Reply With Quote
Old January 6th, 2018, 16:02   #2
PHAT-DUB
PHAT-DUB's Avatar
future post
www.badgeskins.com
Old January 6th, 2018, 16:03   #3
PHAT-DUB
PHAT-DUB's Avatar
future post 2
www.badgeskins.com
Old January 6th, 2018, 18:25   #4
sportwagen3
This is a good thread!
Here's a good post if anyone wants to upgrade their MIB1 to an MIB2 infotainment system. You get a more responsive and faster system with apple carplay or android auto. Just did this recently.
http://www.golfmk7.com/forums/showthread.php?t=31600
sportwagen3 is offline   Reply With Quote
Old January 7th, 2018, 12:16   #5
neimis
Default door check stop mod
Why VW decided to put only a single door check stop at an unusable position (too narrow) with the only other position wide open ("bang against the car parked next to you") is beyond me. Here is how to change to a 2 position Jetta check stop: http://www.golfmk7.com/forums/showthread.php?t=31902
And a couple of door panel removal links to access the check stop:
https://www.autoinstruct.com.au/manu...-trim-removal/
https://www.dropbox.com/s/7ec7td257b...20MK7.pdf?dl=0
92 Passat TD
01 Golf GL TDI
15 Golf Trendline TDI
neimis is offline   Reply With Quote
Old January 7th, 2018, 18:30   #6
Jedadiah
Jedadiah's Avatar
Westfalia Trailer Hitch and Trailer Wiring
http://forums.tdiclub.com/showthread.php?t=478382
How to make your inner tails behave just like your outer taillights.
http://forums.tdiclub.com/showthread.php?t=478893
Full-size spare trim piece
http://forums.tdiclub.com/showthread.php?t=478377
Not mine, but a good link for VCDS coding info for an MK7
https://sites.google.com/a/naturalne...ds-how-to/home
If you move any of these to the top, I’ll delete them here to clean up this thread.
Jedadiah is offline   Reply With Quote
Old January 8th, 2018, 19:14   #7
Mike in Anchorage
Mike in Anchorage's Avatar
Thanks for these. I wrote to one vendor from this site asking about stocking the kit for the Sportwagen rear window side deflectors. I hope it goes well. I'm in need.
~ I'm selfish, impatient and a little insecure. I make mistakes, I am out of control and at times hard to handle. But if you can't handle me at my worst, then you sure as hell don't deserve me at my best. Marilyn Monroe
2015 Tornado Red Golf TDI Sportwagen SE, new on 2 SEP 2017, DSG, big sunroof. Lovin it!
Mike in Anchorage is offline   Reply With Quote
Old January 9th, 2018, 06:02   #8
740GLE
E-ACCA was painless and I'd order again from them, any vendor here will probably order from them as well as they are the cheapest
Hers: 2015 Passat SEL (NOS) w/ VW fix and Malone Stage 2 (low torque for DMF shudder).
Old January 9th, 2018, 06:39   #9
PHAT-DUB
PHAT-DUB's Avatar
Do they ship worldwide? (Canada/USA)
Sent from my ONE A2005 using Tapatalk
www.badgeskins.com
Old January 9th, 2018, 08:22   #10
sportwagen3
They ship to the US. Just takes some time.
Old January 9th, 2018, 12:26   #11
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Subscribed. I've also asked one of the moderators to make this thread a sticky.
-George Bernard Shaw
Old January 10th, 2018, 06:51   #12
Grigg3
VCDS Tweaks:
Great resource, lots of discussion and tweaks (all models/years)
http://forums.ross-tech.com/forumdisplay.php?11-Tweaks
Hill Holder turn off
http://forums.tdiclub.com/showthread...97#post5320397
DTR on and off option
http://www.vwwatercooled.com.au/foru...ml#post1040702
Electrical:
Constant accessory power (charge your phone without car running)
http://forums.tdiclub.com/showthread.php?t=476748
Trailer light wiring for GSW
http://forums.tdiclub.com/showthread...02#post5347402
Under the hood:
Remove clutch delay valve
http://www.golfmk7.com/forums/showthread.php?t=14745
http://www.vwroc.com/forums/topic/12...l-manual-cars/
05 Jetta wagon, 15 Golf wagon
Grigg3 is offline   Reply With Quote
Old January 10th, 2018, 19:36   #13
sportwagen3
Originally Posted by Grigg3 View Post
Have you done this on your tdi? If so, how do you like it on your tdi since the threads are for gti and golf r.
I actually had my transmission completely replaced under warranty (~17k miles) because they found the shifting fork was warped and pieces got into the transmission fluid. I had problems where the car wouldn't shift to first and reverse on cold start unless I put a lot of force. Also, first to second wouldn't shift smoothly. After replacing the transmission I haven't as much problems though I would say that depending on how cold it is outside, it still won't shift smoothly as if the gears are no lt aligned.
Old January 11th, 2018, 07:12   #14
Grigg3
I have not done it yet.
Probably not for everyone. Just guess that many manual drivers these days don’t understand what actually goes on while shifting and would be better off leaving it alone?
While shifting I try to match engine RPM so when the clutch comes back out engine is already right speed for the new gear. Otherwise if RPM is higher or lower the clutch slips and drags engine down or pulls it up to speed, not good for the clutch.
If you remove the delay valve and come out on the clutch real quick while shifting it would do this more aggressively, be harder on everything.
So if you’re good at shifting and matching speeds and occasionaly want to get on it and shift real quick you’ll notice the clutch doesn’t engage fully as soon as the clutch pedal is up, this is the delay valve doing its job.
I’d like to try driving without that.
Mine shifts real smooth warm or cold, never need to “force it”, a gentle nudge and it seems to suck the shifter onto the next gear.
Occasionally at a stop might not drop right into gear, just let up on clutch a tad to rotate the gears a fraction, depress clutch and try again, it'll drop in, don’t force it.
Old January 11th, 2018, 08:12   #15
sportwagen3
Didn't think of that(release clutch a little bit and then depress), but will try that next time especially when driving in traffic.
LIFTING a mk7 TDI Sportwagen thread mxtdiguy VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 18 May 4th, 2020 14:35
Comprehensive con-rod DIY R/R thread DieselDork VW MKIV-A4 TDIs (VE and PD) 0 September 8th, 2015 10:12
Thread with diy for turbo braided oil line? witchcraftz TDI Power Enhancements 9 August 3rd, 2013 23:41
IP Install DIY Thread? sackman VW MKIV-A4 TDIs (VE and PD) 7 December 22nd, 2011 13:27
Underseat Drawer Help Diy Thread 40X40 VW MKV-A5 Golf/Jettas 16 June 9th, 2006 17:42
Page generated in 0.27010 seconds with 11 queries
[Output: 134.26 Kb. compressed to 112.51 Kb. by saving 21.75 Kb. (16.20%)]
