Old May 1st, 2017, 17:29   #1
davidch
TDI(s): None
Default 2015 Golf TDI Highline OEM Sport Springs for Canada
I am considering buying US 2015 Golf SEL TDI. It is my understanding the Canada Highline TDI came with OEM sport springs. Take car - 1/2 in lower and firmer. Does anyone know those part numbers? Thanks.
davidch is offline   Reply With Quote
Old May 4th, 2017, 06:06   #2
davidch
TDI(s): None
any CA folks out there with Highline willing to post a VIN?
Old February 26th, 2018, 14:52   #3
neimis
9 months late, but here they are:
My car (Canadian TDI Trendline) 4 door manual transmission "Standard" springs:
Front: 5QM 411 105 D
Rear: 5QM 511 121 C
Canadian TDI Highline 4 door manual transmission "Sport Suspension" springs:
Front: 5QM 411 105 L
Rear: 5QM 511 121 L
92 Passat TD
01 Golf GL TDI
15 Golf Trendline TDI
neimis is offline   Reply With Quote
Old February 26th, 2018, 15:40   #4
neimis
More information to confirm that these are indeed "Sport" springs
Standard Suspension 4 door manual TDI:
Front springs: 5QM 411 105 D PR code: G01+L07+2UA
PRCode: 2UA = Standard design
PRCode: G01 = Front shock absorption
PRCode: L07 = Suspension range 07 installation control only no requirement forecast
Rear springs: 5QM 511 121 C PR code: 1JA+0YB
PRCode: 0YB = Weight range 2 installation control only no requirement forecast
PRCode: 1JA = Rear shock absorption basic design 1
Sports Suspension 4 door manual TDI:
Front springs: 5QM 411 105 L PR code: G01+L18+2UC
PRCode: 2UC = Sports version
PRCode: L18 = Suspension range 18 installation control only no requirement forecast
Rear springs: 5QM 511 121 L PR code: 1JC+0YF
PRCode: 0YF = Weight range 6 installation control only no requirement forecast
PRCode: 1JC = Rear shock absorption for sports design
92 Passat TD
01 Golf GL TDI
Old February 27th, 2018, 15:49   #5
PHAT-DUB
PHAT-DUB's Avatar
Never knew that i have a manual highline.
Will be removing swapping out the oem springs soon and installing H&Rs
@badgeskins_mk7wagon on instagram
Sent from my ONE A2005 using Tapatalk
www.badgeskins.com
Custom MK4 widebody for sale - here
PHAT-DUB is offline   Reply With Quote
Old February 27th, 2018, 23:33   #6
neimis
Looks like you have a wagon. Damn. I would have liked to buy your springs if it was a hatchback.
92 Passat TD
01 Golf GL TDI
Old March 27th, 2018, 05:15   #7
davidch
TDI(s): None
neimis... good info. i have a dsg. would weight be similar enough to use same setup as your listed manual? thx
Old March 27th, 2018, 08:42   #8
neimis
From what I have been able to find, depending on the source, DSG adds from 20 to 30 kg. more to the weight (probably mostly over the front axle) than a manual transmission.
I'll send you a PM with some more info.
92 Passat TD
01 Golf GL TDI
Old March 27th, 2018, 08:50   #9
jonferns
jonferns's Avatar
TDI(s): '15 Golf
Why not post it here? This is good info that I'm sure a few of us would be interested in.
'15 Golf S TDI - 80k, DSG
'12 JSW TDI - 99k, 6MT Buyback complete!
'06 Jetta TDI - 160k, DSG, Package 2, Malone Stage 1, RCD510 Retrofit
'06 Jetta TDI - 230k, DSG
jonferns is offline   Reply With Quote
Old March 27th, 2018, 14:49   #10
neimis
OK, I found a VIN number posted on a BC dealer's website, so it's public knowledge. Therefore I feel it's OK to post it here: 3VW2A7AUXFM050455
It is a 2015 Volkswagen Golf 5-Dr 2.0 TDI (Canadian) Highline DSG
According to my source, these are the part numbers for its springs:
Front springs: 5QM411105K
PR-G01+L17+2UC
L17 = Suspension range 17 installation control only no requirement forecast
ECS tuning $86.44
Rear springs: 5Q0511115GJ
PR-1JN+0YE
0YE = Weight range 5 installation control only no requirement forecast
1JN = Rear shock absorption
Pelican Parts $113.36
It would be good for someone with access to EKTA to double check that this info is correct.
92 Passat TD
01 Golf GL TDI
Old April 8th, 2018, 06:46   #11
davidch
TDI(s): None
neimis... thx again. one more question. just to confirm the canadian tdi's alos have non IRS (i.e. torsion beam) rear suspension like the US models to make room for the adblue tank?
Old April 8th, 2018, 11:33   #12
neimis
Correct
92 Passat TD
01 Golf GL TDI
Old April 20th, 2018, 10:49   #13
davidch
TDI(s): None
Thumbs up
Correct
thx again neimis... i also came across this detail review of the CAN 2015 Golf Highline
http://www.autotrader.ca/expert/2015...esel-highline/
it even states the sport suspension as part of the package "Top Highline trims ($30,995) add 17-inch all-season tires with “Geneva” alloy wheels, a stiffer sport suspension...". Other differences i noticed between the CA Highline and the US SEL are the real leather vs vinyl seats. Otherwise, the specs look nearly identical. Visually, the CA car height looks to be about ~1/2" (12-15 mm) lower than my US model. Not too much but definitely takes out that strange 4x4 look the US models have...
Old October 10th, 2018, 08:49   #14
CGR
Fuel Economy: 52.5/41/38.5
PR-G01+L17+2UC
ECS tuning $86.44
PR-1JN+0YE
When you put the part number 5QM411105K in to ECS's website, it returns the same spring you get when you do a search for GTI springs. That leads me to believe that the Highline springs are nothing more than a GTI front spring with a matched rear spring for our torsion beam TDI's which is what many of us seem to be looking for. Their website also lists the rear spring as being available when I put 5Q0511115GJ in to the search bar.
I contacted ECS a couple of days ago and they are looking in to finding the correct Driver Gear springs for our car. I am also trying to find out the exact ground to fender measurement for the H&R Sport springs for the TDI. I don't care about lowering the car, I just want a sportier better handling suspension so the Highline springs might be exactly what I am looking for .
2002 Golf 6SP DRW, 293K, RC3Euro, Sprint520's, Boost Guage, Boost Valve, DG Racepipe, Koni Yellow F, Koni Red R, VW GLI SS 2B/2W F, Stock Golf Springs R, Neuspeed 28mm RSB full stiff, Montreal II 16" wheels and Conti Extreme contact DWS 205-55-16. GLI Heated Sport Seats and interior.
2003 Chevy crew cab Duramax. 180k
CGR is offline   Reply With Quote
Old October 11th, 2018, 10:42   #15
CGR
I stopped at my dealer today and did some checking on their system. The front springs 5QM411105K and 5QM411105L are both designated sport springs in their system, and the rear spring 5Q0511115GJ is also designated as a sport spring. The GTI sitting in their showroom had front springs with a part number of 5QM411105AC. It sure looks like the Highline springs are GTI front springs with the correct rear torsion beam spring to match.
WTB: 2015 Golf TDI Comfortline 6M - Highline (Vancouver, BC) garms TDI Cars for Sale/Wanted 2 December 19th, 2016 10:38
2015 Golf Wagon TDI Highline or Bust! doogymon General VW Discussion 0 September 1st, 2016 12:29
2015 Golf TDI Sportwagon HighLine doogymon General Automotive 0 August 31st, 2016 12:34
Golf tdi highline 2015 or 1.8L? TDI2010 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 28 March 28th, 2014 22:14
OEM sport springs: Bilstein HD or Sport? moved2tdi VW MKIV-A4 TDIs (VE and PD) 13 March 7th, 2006 11:44
Page generated in 0.17081 seconds with 11 queries
[Output: 132.47 Kb. compressed to 110.84 Kb. by saving 21.64 Kb. (16.33%)]
