Old April 9th, 2015, 17:50   #1
evguy1
Default BEW / 05 Ranger automatic swap
I had this stripped out 05 Ranger from when we converted it to electric power and then sold the electric drive system.
The Jeep build http://www.cherokeeforum.com/f46/200...blacky-205238/ has gone so well that I decided to start on the Ranger and convert both side by side.
Both use the BEW engine.
The Ranger has a 5R44E automatic and the Jeep has the NV3550 standard.
Got the engine into the Ranger today and hopefully its in for good!
The Ranger will just be left stock other than a Malone stage 1.5 tune and a PD150 intake.
Is anyone selling those at a resonable price?
Here is the TDI block adapter in place.
Had to clearance the trans a bit for the starter drive.
2000 Jeep XJ / BEW http://www.cherokeeforum.com/f46/2000-tdi-blacky-205238/
2008 Dodge Dakota / Cummins ISB170 https://tdconversions.com/dakota-cummins-isb170
2005 Ford Ranger / 1.9 TDI https://tdconversions.com/ranger-1-9l-tdi
evguy1 is offline   Reply With Quote
Old April 9th, 2015, 18:59   #2
A-man930
Subscribing. You do clean work my man.
A-man930 is offline   Reply With Quote
Old April 9th, 2015, 20:25   #3
evguy1
Thanks A-man. I have been doing EV conversions for 25 years.
When your playing with that kind of power it has to be clean!
Old April 10th, 2015, 11:32   #4
Nozzleman
Nozzleman's Avatar
How are you going to control shift points on the transmission?
2003 Jetta (wifes)
2002 Ford Ranger ALH. IT'S ALIIIIVE!
1978 Ford F250 4x4 Supercab 6bta, NV4500, Dana70/60.
Nozzleman is offline   Reply With Quote
Old April 10th, 2015, 21:40   #5
evguy1
Not a clue. ;>)
On EV conversions I have had good luck keeping the stock Ranger ECU to run accessories and also have run automatics this way.
Usually just need a TPS and tack signal to run the ECU but each model and year is different so its trial and error, lots of error.
Old April 13th, 2015, 15:35   #6
chucky2
Subscribed. Man I'd kill for a work area like that!
chucky2 is offline   Reply With Quote
Old April 14th, 2015, 15:11   #7
Tagg33
TDI(s): none yet
I'm subscribed. I really want to do a BEW swap in my 68 Jeepster and I want an auto trans. I'm super excited to hear how this goes for you.
Tagg33 is offline   Reply With Quote
Old April 14th, 2015, 18:45   #8
evguy1
Well it will go slow for a while. We sold some electric trucks this week so my projects will get booted out of the shop till those are built.
I'll try to get some time in on the weekends but that's usually pretty limited.
Old April 16th, 2015, 14:19   #9
Nozzleman
Nozzleman's Avatar
Baumann Transmission controller?
http://becontrols.com/
Are you going to run VW accessories or Ranger?
2003 Jetta (wifes)
Old April 16th, 2015, 20:34   #10
evguy1
VW accessories and I have a Baumann controller from another project that may work.
Old April 20th, 2015, 11:17   #11
dcproven
TDI(s): 2000 beetle
This is a great idea, I wish it was easier in California to do this kind of thing...
dcproven is offline   Reply With Quote
Old May 22nd, 2015, 19:35   #12
evguy1
Finally got some time to build the accessory drive relocation bracket.
It worked out real well with the alternator no higher than the valve cover but the PS pump up a lot higher to clear steering parts.
Old May 31st, 2015, 20:16   #13
Nozzleman
Nozzleman's Avatar
Any updates? I have the donor car and I just bought my truck and am about ready to drop the hammer. I am going to run the 4.0 pattern for the bigger clutch.
For the record, a Ford 2.3 Duratec will weld solid 18 miles after the Quicky Lube forgets to put oil in it.
2003 Jetta (wifes)
Old June 2nd, 2015, 08:53   #14
evguy1
Yes, lots has happened just nothing worth posting about.
This truck had spent the last three years as one of our electric trucks.
We have spent the last few weeks putting all the gas parts back in like fuel tank and lines, cooling system, A/C system, exhaust system along with the PCM and all the engine wiring. Unfortunately we had a big cleanup about two years ago and all those parts went to the scrap yard.
Its been an adventure finding compatible parts as I think Ford changed the wiring layout every year.
This week we did get new exhaust and a fuel tank back in.
The rear axle has to be swapped for a stock one since the electric had 5:36 gears. Luckily that stock 4:11 axle is still here so its a quick swap.
Old June 2nd, 2015, 11:27   #15
cevans
TDI Parts Ninja Vendor
cevans's Avatar
What a cool project!
IDParts.com - IDParts.com Vendor Thread - The IDParts Blog - IDParts YouTube Channel
Current Diesels: '17 Canyon 2.8L DMax, '15 Jetta, '15 Beetle Convertible, '11 R350 BT // Past: 15' Ram ED, '13 NMS, '10 JSW, '10 Jetta Sedan, '07 R320 CDI, '06 E320 CDI, '03 Wagon, '00 Golf 2-Dr, '00 NB (Yellow :-)
Stop Hunting for Torque Specs - Get A Free IDParts Torque Spec Poster Today!
cevans is offline   Reply With Quote
Complete 5-speed swap kit from 05 BEW Redneck Truck Private TDI Items for Sale/Wanted 2 July 8th, 2018 14:29
Starting my 2nd TDI swap, BEW in 05 Rubicon, questions logs TDI Conversions 2 October 22nd, 2014 19:02
05' jetta wagen BEW 5 speed swap question embryriddledude TDI Power Enhancements 5 May 20th, 2014 13:51
TDI to Ford Ranger Swap. JarHead TDI Conversions 9 April 4th, 2012 08:55
WTT: BEW '05 tiptronic transmission for 5-speed swap 54321chris Private TDI Items for Sale/Wanted 4 October 19th, 2010 01:58
Page generated in 0.11298 seconds with 11 queries
[Output: 129.97 Kb. compressed to 108.74 Kb. by saving 21.22 Kb. (16.33%)]
