well i will be putting my old 2003 ALH into my 99 cherokee to make my 11mpg gas 6cyl into a 35mpg ish? fun daily driver.
my jeep forum build thread so far
http://naxja.org/forum/showthread.php?t=1094425
post #85 is where my brother Alex22 says what he did to this motor
http://forums.tdiclub.com/showthread.php?t=307098&highlight=alex22&page=6
we are not happy with the dishes in the piston which caused the compression to lower, harder to start in the winter and poor mileage. it was set up to use the larger colt stage 3 cam.
i have a 17/56 i can use or my old 17/22 although i hear that once you go to the 17/56 you never go back. i would like the more power and higher boost capability that is possible with that.
as for cam, keep the stock or should i go with something larger but one that i can use the standard OEM type valve train so i don't need to custom make something. my brother doesn't have hundreds of hours to spend researching this stuff anymore.
pistons.... i am thinking it would be best to get a set of stock pistons or? not sure what there is for options, going larger isn't something i really want to do with this motor for time restrictions since that requires a complete rebuild.
i will be using the HPA Jeep/TDI kit, well parts of it as they do not have a direct bolt in for an XJ yet but will sell be bits and pieces of the kits they have.
thoughts from you guys?
Jeep pic
since this needs to be a low end TQ and HP motor what mods would you suggest?The engine had about 140K so nothing was too warn out, Here's what I did:
- Decked the block the minimum amount to clean it up.
- Rigid honed the cylinder bores for new ring break in.
- New piston rings on the factory pistons.
- Intake valve reliefs cut .030 deeper and .080 larger in diameter.
- Exhaust valve reliefs cut .045 deeper and .060 larger in diameter.
- Measured clearances.
- All new bearings and bolts.
- Basic 3 angle valve job, intakes and exhausts. When I checked the factory valve job one of the exhaust seats did not lap in so I used the intake seat cutter who's flow and swirl numbers were closest to the factory (marginally better.) I used a basic 3 angle exhaust seat cutter on the exhausts. The factory valves were reground.
- Minimum resurface on the cylinder head.
- ARP head studs.
- 3 hole head gasket was required.
- Balanced rotating assembly to race spec.
- South Bend DD clutch kit with a 22lb flywheel.
- Stealth race pipe.
- New timing set and replaced all of the one time use bolts.
Jeep pic
