Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > Audi SUVs (Q7 & Q5) and other V6 TDIs
Audi SUVs (Q7 & Q5) and other V6 TDIs Discussions area for Audi Q7 and Q5 TDI (2009+ in Canada & the US) as well as others with the V6 TDI such as the A6, A7 and A8 sedans.
Old March 19th, 2019, 09:51   #1
2014 A6
Default SeaFoam
I use Stanadyne fuel additive in my 3.0 TDI. I am wanting opinions on using seafoam every other scheduled maintenance interval. Any mechanics out there have an opinion on adding seafoam to a tank of diesel every 20,000 miles or so? Pros/Cons? Benefits for a diesel? Could it harm components? As always, Thanks!
2014 A6 is offline   Reply With Quote
Old March 19th, 2019, 10:16   #2
oilhammer's Avatar
Fuel Economy: fantastic
We use BG products here. I doubt Seafoam would harm anything, but if it would actually do anything positive is probably difficult to say. I'd stick with Power Service, Liquimoly, Lubromoly, etc. if I was not using BG. And to be honest, a prophylactic approach while certainly not a bad thing, may not ever reveal it actually did anything one way or the other. Which is always the kicker.
I know for sure BG stuff can improve things if there is something it CAN improve, if that makes any sense.
www.cardocautomotive.com
Old March 19th, 2019, 11:01   #3
2014 A6
Thanks Oilhammer. Are the BG products you use just fuel additives or a fuel system/intake service offered by mechanics where special equipment is required?
I get you on the it can improve things if there is something that can be approved.
Old March 19th, 2019, 13:50   #4
oilhammer's Avatar
There are several things we do, but for the diesels it is just something you add to the fuel tank, no special equipment. It is the 245 Premium Fuel System Cleaner.
We also do some crankcase treatment, which is a two part setup, one can goes in the engine and run for a few minutes BEFORE the oil is drained, then another one goes in AFTER the oil is refilled. While this can be used in diesels, there really is not much of a need. It is best for the DI gas engines that often tax the oil as well as known oil-burners that can help clean the piston rings.
Old March 19th, 2019, 16:18   #5
Pittdawg
I use Lucas Diesel Deep Clean and Stanadyne whenever the local auto parts store has a buy one get one free special, which is quite often. Can't say for sure it helps but certainly doesn't hurt and seems like some relatively cheap insurance.
Pittdawg is offline   Reply With Quote
Old March 20th, 2019, 11:02   #6
ToBiN
ToBiN's Avatar
+1 for BG and Seafoam products
My fam has used Seafoam for years. Ive witnessed seafoam working on many gummed up injectors and fuel systems. We only use it on the fuel systems every 6 months.
In crankcase we use BG MOA for the gassers and BG DOC for the diesels. Engines are happy, they run smoother, and start easier.
I also send off a oil sample to Blackstone labs at every oil change for analysis. Many times I have had responses like "oil looks great! Your metal per mile is minimal. There is 10k miles on this sample, next time you can go for 12k before change. Plenty of viscosity and oil life left."
FWIW, I just bought a 2006 5.9L Cummins. 85k on a rebuild. That engine builder recommended a pint of 2 stroke oil in every 25 gallon tank for lubrication and healthy injectors. I am weary of even trying that in the VW because they seem to be more finicky than the ol' cummins.
ToBiN is offline   Reply With Quote
Old March 20th, 2019, 12:11   #7
2014 A6
This is some great information, guys. Thank you! I ordered Some BG 245. I’ll use it at every oil change and stanadyne with each fill up (if I remember...it’s the wife’s car ever since she drove it, loved it, and now won’t give it back). Seafoam in the gasser, BG in the diesel. That’s the plan.
Old August 4th, 2019, 14:22   #8
Anomious
Seafood = snake oil!
Anomious is offline   Reply With Quote
Old August 5th, 2019, 14:32   #9
Huskies2710
Huskies2710's Avatar
With my '16 A6 that is tuned and deleted. I'm using ULSD #2 only. So I'm not getting the lubricity they say is good with biodiesel.
I started with the Stanadyne Fuel Injector cleaner which is supposed to help these common rail engines. I can say the smoke has dropped considerably to only noticeable when WOT. After that bottle every other fill up I put some Stanadyne Diesel Performance formula in. Find an ebay discount or buy in bulk to save some money. I don't feel so bad using it a little more often now.
Snake oil, who knows but my car has less smoke and i'm getting 28 mpg city and 38 mpg highway.
Huskies2710 is offline   Reply With Quote
Old August 8th, 2019, 22:12   #10
Anomious
I am using PS in the white bottle.
Seafoam never did do anything for me. I will check out Stanadyne!
Old August 11th, 2019, 07:28   #11
Midwesthick
TDI(s): A6, Q5, Golf
Fuel Economy: 32+
I use a Motul oil with BG DOC for the oil change and then 8-10oz(I don’t accurately measure, just a good eyeball) of Power Service grey bottle with every fuel fill-up.
I used the BG fuel injector cleaner when I got the car but no need to run that super often i was told.
Midwesthick is offline   Reply With Quote
Old August 11th, 2019, 08:07   #12
johnsTDI
Location: Canada,ont North America were Neighbours to usa
Fuel Economy: oh gosh alot better than burning Gasoline.?
i have tried Seafoam in the past when i owned a gasoline engine notice very little difference but not everybody has that result with seafoam it works better for some than others. i have used BG products in the past and they are above and beyond better than any off the shelf cheap additive i ever used i will be running some 244k or the newer 245k for Diesels if i can find someone that carries it. not that theres any problem with my TDI just as a maintenance thing im willing to use.
Satan puts the Fear & Deceives You. If he wanted to hurt You. he would of done it already. Got it.?
"Give Jesus Permission to come into Your Life". & everything else including Your VW will like it.
https://www.youtube.com/watch?v=dB18p5JiFfYhttps://www.youtube.com/watch?v=AKniy8CCKgs
johnsTDI is offline   Reply With Quote
Old August 11th, 2019, 08:43   #13
P2B
P2B's Avatar
I bought a boat with an older 2-stroke outboard recently. Ran ok at speed but would not idle and would quit going into gear.
Marine mechanic suggested running seafoam through it, which killed it completely - wouldn't even start after half a tank of fuel with seafoam added.
I pulled the carbs and cleaned them with naptha and compressed air, motor runs like new now.
I assume the seafoam dislodged crud in the carbs which then moved elsewhere and made the problem worse.
Simon
Jettas for 35 years, TDIs for 16.
2003 Silver Jetta TDI GLS 300K PP520 RC3 6-Speed ERF
2003 Silver Jetta TDI Wagon 230K PP520 RC2
2000 Canyon Red Jetta TDI GLS 560K
P2B is offline   Reply With Quote
Old January 22nd, 2020, 15:48   #14
ToBiN
ToBiN's Avatar
so its been a while, but my 5.9 Cummins started throwing a glowplug light and 10 chimes. Then everytime I start the engine the light returns and it chimes 3 times. After looking up this error, I see many have replaced their injectors. Something to do with the return on the CR, the computer thinks there is a bad injector or 2, so in their infinite wisdom, Dodge added this error to keep the cummins from melting down like other diesels.
While searching for my truck I looked at an 06 with 299k miles on it. Only had the CP3 replaced once. Owner had been running seafoam religiously for the life of the truck every 3 months. Never had an injector issue, not one.
So after discovering this new injector error on my 06, I started putting in a bottle of seafoam for every tank. In about 5k miles, a new fuel filter, and running the Seafoam, my injector error is gone. Injectors are clean and truck is running a lot better.
BG makes a great product. Seafoam is also a great product.
You can check some of these tests out. This guy does a great job of comparing the chemicals.
https://www.youtube.com/watch?v=prXiQgVVnDY
https://www.youtube.com/watch?v=agAWXnT4-EQ
Old January 22nd, 2020, 17:59   #15
AndreiMTM
TDI(s): 2014 A6 TDI
I donít think that the stanadyne fuel performance additive is snake oil. I had a very strange sputtering issue on my 14 A6 TDI when cold. The car would sputter almost as if it wasnít getting enough fuel when at low RPM randomly. It wasnít the fuel filter as it was doing it even when coasting. Using stanadyne every fillup, the sputtering is almost completely gone. I very rarely feel it, maybe once a week. I would highly recommend using it. Iím not sure what the issue was but the fuel additive took care of it
AndreiMTM is offline   Reply With Quote
SeaFoam Automann Fuels & Lubricants 10 January 21st, 2018 23:06
SeaFoam steve1173 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 58 November 12th, 2011 08:00
Seafoam DRbillZ VW MKIV-A4 TDIs (VE and PD) 14 October 28th, 2008 09:17
SeaFoam??? Str9012 TDI 101 16 March 18th, 2007 10:32
Seafoam it? 97B4TDi TDI 101 3 February 5th, 2007 06:47
Page generated in 0.11731 seconds with 13 queries
[Output: 129.03 Kb. compressed to 108.31 Kb. by saving 20.72 Kb. (16.06%)]
