Macradiators.com
Classic GTB2565VK will do over 400hp and cost is under 1000.
My current turbo is slightly larger than that, I'm looking for more power Im running a GTB2568VKClassic GTB2565VK will do over 400hp and cost is under 1000.
On 1.9? U wish...Do you have a dyno run to post? What numbers do you have ? Around here 2565 setups do 430-440hp with high egt i imagine.
It should be spooling from 3000-3500rpm and having full boost around 4000-4500rpm full loaded. It has been told spooling same as hx35 8cm but providing more oomph. As it is drag racing car I wouldnt be worried, since you can use for example shot of nos for off the line spoolup.Courios on what it’d spool like my 6cm hx30 is roughly .41 with a ported wastegate
hx30s are kinda stone age even compared to hx35sCourios on what it’d spool like my 6cm hx30 is roughly .41 with a ported wastegate
of course not but the nozzles yesThe turbo is definitely not limiting performance in an ALH but the VE injection system. It can be resolved by brute force with an upgraded pump, very large hole nozzles and competent tuning to orchestrate everything together.
