Mikkijayne
Nearly there!
What are those wheels? They look almost like Fuchs reps?
They are in fact Fuchs repros. They're Outlaw wheels by Fifteen52, with cutouts in the petals for increased airflow. They've been sitting in my garage for a year, just waiting to be installed. They only make them in Porsche bolt pattern and hub, so I had to get wheel adapters and specific lug nuts to get them to fit.What are those wheels? They look almost like Fuchs reps?
We'll look after you when the time comes. Always nice to see this kind of dedication with custom builds. Just send some solid photos our wayI spent $742 on a custom tune (and flashzilla tune loader) and have almost nothing to show for it. Granted, this was over a year ago and I'd totally expect to have to pay more to get the tune finalized at this point.
Cruise works in no gears. According to VCDS, the ECU sees all the switches (clutch, both brake switches, all cruise switches) and cruise control is enabled. But the reported speed in the ECU is about 15% to 18% off from the instrument cluster speed. The instrument cluster is accurate, so the ECU speed is somehow being calculated wrong. From what I vaguely remember reading, cruise will not engage when ECU vs cluster speed difference is more than 10% because the calculated gear ends up being wrong. The ECU has no way to know what gear I'm in except by calculating RPM vs speed and referring to its internal gear ratios table, including the final drive.Does cruise work in any gear? I had to get Malone to adjust mine when he got the 6th gear ratio wrong, it would work in gears 1-5 though.
Have you checked that the cruise switch and clutch/brake switches are working in VCDS?
Oh I've been driving it for almost 30k miles this thing is by far my favorite car everThe best car is a wagen awd diesel right ?.
Its an old thread bit i hope to see some progress.
