Old February 26th, 2020, 19:58   #1
BigT
Default B4 Passat Seat Removal
I'm restoring a 96 Passat TDI. I want to take out the front seats. What's the trick in getting them out?
BigT is offline   Reply With Quote
Old February 26th, 2020, 22:21   #2
Steve Addy
TDI(s): 97 Mk3
There a long slender reveal trim next to the console that has to come out and there's a small cap at the rear of the rail next to the door, take that off.
In the front center there's either a spring clip or allen bolt and 10mm nut that keeps the center rail from sliding back and out. Remove that bolt (or spring clip) and then slide the seat back and out until the rear feet are out of the rails.
Tip the seat up and unplug the seatbelt connection and if you have it, the heated seat elements. Push the front back down and pickup the seat, bringing it forward and out through the front door. Be sure it's not reclined too far.
Steve
the magic triangle spins in the peanut and then apex seals come out
Strava
Old February 27th, 2020, 19:29   #3
BigT
Thanks Steve...I'll give it a try this weekend.
Old February 28th, 2020, 05:02   #4
JETaah
Take a sawzall and....
JETaah is online now   Reply With Quote
Passat Seat Removal johnboy00 VW B5 Passat TDIs 5 January 27th, 2015 11:03
B4 Passat headlight removal scmadm VW MKIII-A3/B4 TDIs 6 September 6th, 2009 12:59
97 Passat B4 - Seat heater burnt a hole through the seat . Recall? rsd VW MKIII-A3/B4 TDIs 5 January 21st, 2006 14:56
ECU removal from B4 Passat? JerryPT TDI Power Enhancements 4 January 15th, 2003 16:21
97 passat front seat removal andy944 General VW Discussion 17 September 12th, 2002 16:29
Page generated in 0.07936 seconds with 12 queries
[Output: 63.01 Kb. compressed to 56.47 Kb. by saving 6.54 Kb. (10.38%)]
