Old June 13th, 2018, 17:06   #16
Mike_04GolfTDI
Mike_04GolfTDI's Avatar
I just put some black INA lifters in my engine a few days ago and nothing weird happened.
2004 Golf GLS TDI 5-spd, DC Stage 1 Clutch, Evolution Atlas Skid Plate, Malone Stage 4 Tune, GT1749VB Turbo, 3 bar MAP
Mike_04GolfTDI is offline   Reply With Quote
Old December 14th, 2019, 10:44   #17
Cjensan
TDI(s): V10TDI
The video linked is my video.
The large spring inside the lifter, in addition to the 3 piece piston design results in a hydraulic lifter that runs a valve lash of around 0.014".
The diesel motors are too loud for you to hear much of a difference.
As mentioned in the video they were installed in a 1991 928GT with heavier valve springs (seat pressure around 90#). With them installed the idle was not consistent, and the car was not making the same power as before.
The car was also noticeably louder at idle and sounded like a solid lifter engine with the lash set too large.
Upon removing that large spring (not the small spring which keeps the check valve ball in place) the engine was back to being properly quiet and back to making full power.
The factory cam grinds have a ridge in them that is around 0.011" and you see numerous companies offering up a "true hydraulic grind" on the cams. The factory added this spring in an attempt to help reduce wear by having the hydraulic lifters maintain a valve lash like you would have in a solid profile grind. But the solid profile grinds use an entry ramp followed by a quietening ramp. The factory VW grind has something like an entry ramp, but no quietening ramp to follow it.
So if you are using a factory camshaft that has never been reground with a proper hydraulic grind, then use the lifter with the spring. If you are running a cam with a hydraulic grind you will see more life and likely an increase in power from removing the spring from the lifter.
Cjensan is offline   Reply With Quote
Old December 14th, 2019, 11:45   #18
Yourbuddysatin
Fuel Economy: 32-35mpg
Reviving old threads is getting popular.
Yourbuddysatin is offline   Reply With Quote
Old December 15th, 2019, 04:57   #19
Markus L
So what's wrong with bumping 1Ĺ year old thread with more detailed information?
Markus L is offline   Reply With Quote
Old December 18th, 2019, 15:02   #20
PakProtector
At some point, I will be doing a BEW cam. While this one has my attention, I think I am going to see if any other info comes to light to explain why this is such a threat.
cheers,
Douglas
1990 D250, NV5600, Luk 05-101, 16cm housing, TST Kit KDP tab, 366 spring, Powr-Lok'd 3.07, HX35...IC soon
She wasn't built to travel at the speed a rumour flies
2004 Jetta, 5spd...stock and turning 47-48mpg
PakProtector is offline   Reply With Quote
Old December 19th, 2019, 19:29   #21
turbovan+tdi
turbovan+tdi's Avatar
I took the spring out, engine is quiet, so meh! Lol.
1984 6.2 Diesel Get A Way van, remote turbo setup designed/installed by me, burning anything that burns.
2003 GSW, 2.0L ALH, Stage 2 Colt Cam, 1756 turbo, auto, silver, 380k-Wife's.
2004 GSW TDI, blue, 5 speed-Malone stage 2, no kitty, aeroturbine muffler, PD150's, PD150 turbo.
turbovan+tdi is offline   Reply With Quote
Old December 19th, 2019, 19:29   #22
turbovan+tdi
Exactly.
Old December 22nd, 2019, 15:38   #23
Blownvette
Originally Posted by turbovan+tdi View Post
Exactly.
Especially when the poster is a very well experienced cam installer. Wish he was on the east coast of the USA and I could have him install my stage 3 v10tdi cams. I know he got his when I got mine and canít wait to get them in!
Blownvette is offline   Reply With Quote
Old February 27th, 2020, 01:20   #24
toefuk
TDI(s): A4 1Z 1996
Hi all,
I did head gasket job last saturday but things get wrong.
Head was rebuild (grinding/valve guides/etc.).
I checked timing twice after installation. It was fine. Than I disconnected IP (VP37) and start cranking to get oil in the system and in the lifters. After 10-15 seconds of crancking pistons starts to hit valves.
I checked timing again but it was OK.
Then I swaped to old lifters and pistons stop to hit the valves, so I connected the IP connector and engine starts ok.
What should happen?
Now I have power loss and white smoke during cold start. So I think that valve(s) are not sealing well now.
Hope that conrods are OK.
A4 1Z, GT2052S, PP764+11mm+DE643, KAT out, MAF off-MAP on, 550x140x65, downpipe, 4bar MAP, 2.3 20v clutch
A4 AHH EDC15V, GT1852V hybrid with improved bearings on REA, WZM 0,260
toefuk is offline   Reply With Quote
Old February 27th, 2020, 03:28   #25
Yourbuddysatin
Probably bent valves.
2004 BEW Cam lifter failure pictures Drivbiwire Fuels & Lubricants 372 August 19th, 2011 05:26
BEW Black Cam Lifters eddif TDI 101 31 June 6th, 2010 06:51
2004 BEW Cam lifter failure report Drivbiwire Fuels & Lubricants 394 December 10th, 2008 08:03
Rotating engine using cam holding bar? Herph TDI 101 35 December 17th, 2006 19:46
$7.99 Cam Sproket Holding tool LanduytG VW MKIV-A4 TDIs (VE and PD) 5 August 12th, 2003 17:41
Page generated in 0.09358 seconds with 12 queries
[Output: 98.05 Kb. compressed to 83.68 Kb. by saving 14.36 Kb. (14.65%)]
