MaineMechanix
Hey guys first post here, done a lot of lurking here (lots of general VW info around here) and decided to register for this one.
I have a 2007 VW rabbit 2 door, 2.5 I5, 5 speed. It's got 175k and the other day it started leaking antifreeze out of the coolant temp sensor, prompting it to over heat, and then the next day my crank bearing came to a screeching, smoking, oil boiling stop(I pushed it trying to get the car home).
So I got to looking around and couldn't find any cars with running 2.5s under $1000. Call me crazy but I ain't paying $1000 for a used engine. But what I did find is several MK3 Jetta and golfs with AHU engines that run, the body's are just rusted and aging. I can pick one up for $500 or less for the whole running driving car. I love turbo diesel's and have always liked TDI's so it seemed like a good option.
I know you guys are going to say just skip the BS and go for the ALH with the VNT turbo. But they are average $800 for an engine only in my area and for me the AHU is skipping the BS, there's no immobilizer, very basic engine harness, so basically it will be the easiest to drop in my bunny and get it going, no computer tuning should be needed.
I have a few questions, and as far as I have found no one has done exactly what I plan to do, probably with good reason.
1. ECU- seems to me I should be able to run the ecu from the engine donor car to control the engine, but will I need to keep my factory ecu in my rabbit to control other things?
2. Transmission- from what I have read the AHU block should bolt to my 5 speed transmission in my car, is that correct?
3. Engine Mounts- I have read that MK3 and MKIV mounts are interchangeable, any such luck with the MKV or did they change the design?
4. Fuel Tank- I have my doubts that the MK3 tank out of the donor car will fit my MKV, does anybody know if the pump will fit in my tank?
5. What is involved in having immobilizer deleted for a ALH ECU and what's the average cost? At this point that's my biggest hold up on the ALH, because I was rather have one in my car but it seems like it would cost twice as much.
Thanks in advance any input is appreciated thank you!
