Lenard
- Joined
- Apr 26, 2017
- Location
- Lake Mills, WI
- TDI
- 02 Beetle "skeetle" Previously: 98 ahu jetta, 05 bew jetta, 97 1z b4 sedan, 2004 bhw passat, 02 alh jetta, 2005 bhw passat, 97 b4v glx 1z swapped, another 98 jetta. Honorable mention: 81 jetta coupe 1.6d
So I recently picked up a 2005 Passat TDI with a junk trans. For $500 I figured why not, I could part it out and make money at this rate. However my girlfriend is in dire need of a different vehicle. She loves the Passat but doesn't want to drive a car with an automatic, so putting a new auto in is out of the question. We looked into 5 speed swapping the passat and the pricetag for a complete no ends left untied swap is 1.5 to 2k. Well I have a known good 02a sitting in the shop right now. Bolts up. Okay cool. Now I just need to find the swap car. I can get a near completely rust free mk3 jetta gasser shell for $100.
So things I have are, pedal cluster from an a3 TDI car, 02a from an A3 TDI car, axles etc. I understand I'll need to have the IMMO defeat done if I want to retain the cluster in an a3 car, which I also have access to a cluster. The cluster even reflects very similar mileage to what is on the BHW which is a plus. And then I'll need to sort some wiring out, which is a non issue. If there's anything I'm missing please chime in. If there's an easier car than an a3 to swap a BHW into that would be nice to know. Thanks ahead of time for any input
