MethylEster
See the new sticky in the Diesel Emissions forum.
There is info on the new Vag Com DPF regen settings.
I ran B99 until the OA at 4,000 miles. I'm currently at 7,300 miles. I'm running ULSD until my dealer oil change at 10K. I'll get another OA at that point. Then I'll switch back to B99 thru 15K (with oil change and OA), then back to ULSD thru 20K (again with oil change and OA). The 5K B99 interval will get shortened if oil dilution is occurring again.tdimama said:Are you running on petro diesel until 5k and getting an oil analysis again? What will it tell us? Does this mean that it's not as bad as we think to run on B99?
Thanks so much for all your work!
2.5% of 5.8 quarts is 4.6 ounces. Unless Blackstone's analysis is off by almost an order of magnitude, fuel dilution cannot possibly be the cause of your sump overflow.rodneyh1 said:Finally figured out how to post my oil analysis. This is at 4K running only B99. Polaris apparently has a better fuel dilution test, so I've sent them a sample as well. Will post that analysis when I get it back.
http://pics.tdiclub.com/data/500/Blackstone_Oil_Analysis.pdf
Did he get 5.8 Quarts out when he drained the oil??? Capacity is 4 Litres or about 4.2 Quartsjvance said:2.5% of 5.8 quarts is 4.6 ounces. Unless Blackstone's analysis is off by almost an order of magnitude, fuel dilution cannot possibly be the cause of your sump overflow.
From the engine oil capacity listed on VW's website. I should look in my Owner's Manual and confirm. If what you say is true, then 2.5% of 4.2 quarts is about 3 ounces, and if you look upthread he pulled 24 ounces of excess oil from his engine. Maybe something weird is going on, but it can't be blamed on that 3 ounces of BD in the crankcase. There're still 20 ounces of oil to account for. I'm betting overfill at the factory.79RabbitDSL said:Did he get 5.8 Quarts out when he drained the oil??? Capacity is 4 Litres or about 4.2 Quarts
When I reach 10K miles, I will be switching back to B99 until I get up to 15K miles. Then I'll switch to ULSD until 20K. At that point, if it really looks like B99 won't be working out, I'll go to a lower percentage. I'm not too concerned about warranty, so I'd probably try something in the B20 - B50 neighborhood.Frames Fan said:Rodney,
As a new '09 Jetta TDI owner, thanks for taking the plunge for the rest of us. Question for you based on your last post where you say that you won't be putting B99 in (which sounds like a smart strategy based on your results and the analysis here). Are you going to run 100% ULSD or will you consider B5 (or less) given that falls within VW's warranty limits?
I like the way you think. Unfortunately, at least around here, aggressive driving is constrained by the volume of traffic on the roads.IndigoBlueWagon said:I have a corralary thoery: a chipped and aggressively driven '09 may see regen less often and acheive better fuel economy than a gently driven stock car.
My car's had no problems with regens throwing error codes.IndigoBlueWagon said:Chill and I were talking about this last night and wondered how much driving habits affect success rates with biodiesel. It appears that the '09s go through regen less often if driven hard enough to keep the CAT at 360 degrees or above (I'm not sure of that temp, but I think it's what Chill said). If the car is driven at highway speeds, on longer trips, or in a brisk fashion that achieves that temperature frequently, regen will happen less often and fuel economy may be better. At least that's what I understand.
Biodiesel blends have two characteristics that may reduce exhaust temperatures. First, the higher cetane will lower EGTs because more of the combustion event will take place in the cylinder before the exhaust valves start to open. Second, the moisture content of biodiesel may lower EGTs. These two items in combination may cause regen to happen more frequently, again, depending on how the car is driven.
Perhaps I have to get a Sportwagen and test these theories.
That sounds conservatively safe to me.MBoni said:... I wonder if the problem of regen EGTs has a much simpler solution: B20 thru B50?
If B100 is just on the limits of being out-of-range (such that driving patterns make the difference), then B50 could bring things back to acceptable ranges for a wide range of driving patterns.
This is all great input but, I think we need to confirm the fuel dilution issue first because if this is a real issue, all the other possible remedies will be mute barring Federally illegal actions. Later!rosycrown said:That sounds conservatively safe to me.
I'm wondering if you had the temperature that is reached during the regen event and the ignition temperature of both the diesel fuel and the biodiesel fuel, could someone with math skills figure out what percentage of diesel fuel would be needed for the regen to complete. Would it be a ratio of the ignition temperatures?
Wow.rodneyh1 said:My Jetta had to be towed to the dealer last night. Not BD related, as I haven't run any in about 4K miles. It started right up, ran for about 1 second, and died with a "shudder". Tried to restart, but it just cranked with absolutely no firing at all. Has compression, but doesn't feel quite right. It is pretty cold here right now. It was about 35 yesterday when this happened. Hopefully, I'll here from the dealer this AM. For now, I'm back in my '86 Jetta running a sweet BD blend.
