Old December 8th, 2017, 18:09   #16
jerrymander
jerrymander's Avatar
Fuel Economy: 286 lbft
The emphasis on green technology is only because the alternative might hurt their image and therefore their wallet.
jerrymander is offline   Reply With Quote
Old December 8th, 2017, 19:26   #17
dieselpwr
Originally Posted by St.Hubbins View Post
you'd think with all the emphasis on green technology and enviro-friendliness, this would be standard. instead, if you arrive somewhere and don't want to interrupt a radio interview, for instance, you have to sit and idle until the break?!
it dudn't add up, i tells ya.
you can shut off the car and then press the left radio knob and it will turn the radio on
dieselpwr is offline   Reply With Quote
Old December 9th, 2017, 04:11   #18
jason_
Ignition on is required for Bluetooth though
Sent from my One using Tapatalk
jason_ is offline   Reply With Quote
Old December 9th, 2017, 05:17   #19
adjat84th
adjat84th's Avatar
Fuel Economy: ~50 in mixed driving
Yep, which I do. Just turn off lights and HVAC fan if they're on. Still annoying because Bluetooth doesn't always connect lightning quick.
Sent from my Pixel using Tapatalk
adjat84th is offline   Reply With Quote
Old December 9th, 2017, 06:04   #20
dubStrom
dubStrom's Avatar
We know that. But in my '03 Jetta Wagon, I can turn off the car and the radio stays on until I pull the key. Convenience. As I recall, in my MK6 I could even pull the key, and the radio would stay on until I opened the door. Even more convenient (can anyone verify this?).
Lost my JSW to a reckless MB E350 sedan driver blowing a stoplight:
http://forums.tdiclub.com/showthread.php?t=472255
Working on a replacement project:
http://forums.tdiclub.com/showthread.php?t=472257
dubStrom is offline   Reply With Quote
Old December 9th, 2017, 06:08   #21
adjat84th
adjat84th's Avatar
My '01 stays on till key is removed, and MK6 stayed on till door opened...correct!
Old December 9th, 2017, 06:34   #22
jason_
09 was like 45 minutes or an hour? Something long.
My cue to get to work after clocking in and parking for an hour.
FIS Cluster Adaptations Farfromovin Upgrades (non TDI Engine related) 9 July 25th, 2011 11:18
ECU adaptations under load? ini TDI Power Enhancements 4 September 21st, 2007 09:51
Adaptations not saving permanently. OldVolks OBD Scanners 8 February 16th, 2004 20:20
Reset the adaptations? volks27 OBD Scanners 1 March 22nd, 2003 22:34
Performance Adaptations Proud2beloud TDI Power Enhancements 3 March 20th, 2003 14:20
Page generated in 0.12182 seconds with 12 queries
[Output: 83.77 Kb. compressed to 73.05 Kb. by saving 10.73 Kb. (12.80%)]
