Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Past TDIFests > TDIFest 2010
TDIFest 2010 Discussion about TDIFest 2010 on the Labour Day weekend (September 3-5th, 2010) .
Old August 30th, 2010, 15:11   #1
vwmikel
vwmikel's Avatar
Default TD Tuning @ TDI Fest
I wasn't sure what was happening until now but it would appear that I will be making it and will have some sort of booth set up. I'm planning on bringing some loaders and and various tuning equipment. I'm also trying to think of something that I could do for specials so if anyone has anything in mind please let me know and I'll see what I can do to make it happen.
Edit: I will also have a couple of socketed '99.5 ECU's if anyone wants to exchange theirs and get a tune/hot start fix. If anyone is flying in you may also consider bringing your ECU to have it bench flashed (depending on what you need).
vwmikel is offline   Reply With Quote
Old August 30th, 2010, 15:34   #2
greengeeker
greengeeker's Avatar
Fuel Economy: 42.2/50.0/58.1
Maybe sell rides in your Golf?
- Nick -
02 Jetta TDI 308k (42.2/50.3/59.4 MPG) // 01 Eurovan 24V (18 MPG) // 00 TDI Ranger (39MPG)
How to Post Pics - How to Search
TDIclub trusted mechanic in Minnesota - PM me
greengeeker is offline   Reply With Quote
Old August 30th, 2010, 16:01   #3
vwmikel
vwmikel's Avatar
Unfortunately my Golf is about 2 states away at the moment.
Old August 31st, 2010, 00:42   #4
Farfromovin
Torque Addict
Farfromovin's Avatar
Fuel Economy: low: 35 high: 56 avg: 42.0
Bump for the best tuner in the states.
[/old setup]212whp/354 ft-lbs14.862@96.677-Way faster than Chris [/new setup] At least 213whp, and way way faster than Chris.
Farfromovin is offline   Reply With Quote
Old August 31st, 2010, 07:36   #5
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old August 31st, 2010, 12:22   #6
bluboy
What tuning options are there for my 2010 TDI Sportwagen?
bluboy is offline   Reply With Quote
Old August 31st, 2010, 13:29   #7
vwmikel
vwmikel's Avatar
Sorry, but I don't have anything available for your 2010 right now. Malone Tuning is probably your best bet.
Old August 31st, 2010, 14:16   #8
sackman
sackman's Avatar
Yep, I've got a 99.5
2003 2Dr ARL/ASV.
sackman is offline   Reply With Quote
Old August 31st, 2010, 16:57   #9
vwmikel
vwmikel's Avatar
Well, I have two socketed currently and a third which I will try to get done by this weekend. If we can arrange things in advance it would be helpful as I'm sure it will be a busy weekend.
Old September 2nd, 2010, 17:55   #10
Doka TDI
Doka TDI's Avatar
TDI(s): 05 & 06
Will you be able to flash an 05 ECU?
Doka TDI is offline   Reply With Quote
Old September 2nd, 2010, 18:08   #11
tongboy
tongboy's Avatar
Fuel Economy: great and surprisingly not bad, depending on which car
Ooh, can I hit you up for a tweak tune? I'll get you some logs later this evening. Need to play with my VNT actuator again, Travis had it setup perfectly but now it's sticking again...
don't bother with other tuners folks - this is the guy to go to.
4 door Rabbit TDI Swap
has been pulled apart and is now a
mk2 big turbo TDI swap 15.2 @ 101 3.2 60' - rearended - buy the parts car!
The faster car: 97 M3 with an all aluminum american V8 12.6 @ 116 2.0 60'
tongboy is offline   Reply With Quote
Old September 2nd, 2010, 18:35   #12
vwmikel
vwmikel's Avatar
Yes. Please let me know what you have in mind.
I'll have my eeprom programmer there and set up.
Old September 2nd, 2010, 18:41   #13
tongboy
tongboy's Avatar
<3 - thank you, I'll bring a torx this time instead of an allen wrench
Old September 2nd, 2010, 18:52   #14
vwmikel
vwmikel's Avatar
I should have my torx.
Page generated in 0.12222 seconds with 12 queries
[Output: 124.31 Kb. compressed to 103.44 Kb. by saving 20.87 Kb. (16.79%)]
