tbeetle
Having had the classic window falling into my passenger door. (British spec.) I bought the kit from VW and replaced the mechanism on saturday morning. No problem.
When I reassembled everything in order I refitted the door lock etc. Unwisely, without checking I closed the passenger door and disaster. The door will not open again. I checked the pull cable attached to the internal lever handle and it seems loose compared to its action before I started. I got to this by carefully prising off the internal panel again.
Even pulling the cable will not release the door. Movement of the external handle and the cable pull do not seem to connect although there is movement between the two. I did reseat the cable connection at the external handle. How do I get in?. Whats wrong? I am stuck with a car I cannot get into. The electric lock works, everything else responds as it should. What is the problem and how do I get into the door again if ever.....
Thanks.
Thanks.
