Rigger007
I'd like to put some sportier springs on my '10 Jetta and have some questions about the Driver Gear springs.
I know the ones for '10 Jetta's don't list the TDI under models, just 2.0 and 2.5 with either the 6MT or DSG. I'm concerned about spring rates with these, as Eibach makes a spring specifically for the TDI. Also I've noticed the MK6 Golf DG springs have two part numbers per wheelbase, 1 set for 2.0 and 2.5 with either transmission or the TDI with the 6MT, and another part number for the TDI with DSG. This leads me to believe there are some real differences between the engine/tranny weights that should be considered.
I wonder if VW decided one spring rate worked better for the gassers regardless of tranny and TDI/6MT, and that they only needed to increase it for the TDI/DSG combo. Would the springs for a MK5 2.0/2.5 with DSG be more appropriate for a TDI regardless of tranny, or would it be better to stick with the tranny specific springs even though It's a TDI not a 2.0/2.5
I'd love to hear from an Eibach tech on why they made a specific rate for the TDI. Thought I had read something in a forum from them somewhere but can't find it now.
Who has installed the DG springs, which transmission do you have, and which springs did you get? Are you happy? Do you have a skid plate and how much does that affect the performance?
Long post and lot's of questions I know,
